DIY A/C system replacement...
Old 12 Aug 2012, 10:07 am
Default DIY A/C system replacement...
Anyone here ever replaced their A/C components themselves?
According to the dealer mechanic I took it to,my 2003 needs a new compressor and dryer, which is a $1000 job. There's also a leak from a switch on the compressor so I've lost the gas.
I was wondering how hard it would be to take out all the old components, replace them? I would just need to take the car in for filling up of the gas.
A local mechanic says he'd charge $300 for the filling up but since they wouldn't be doing the work themselves, couldn't give a guaranty.
Anyone here has gone through this process? Where would be the best place to buy the components?
Old 12 Aug 2012, 10:29 am
SpannerHound's Avatar
Smile Re: DIY A/C system replacement...
This has been discussed recently, have a read of this:
help please!
Old 12 Aug 2012, 02:35 pm
JenneK's Avatar
Default Re: DIY A/C system replacement...
$300?? What a rip off!
You can do this but you need to be able to purge everything out of the lines and condenser & evaporator before you button everything back up.
Why do you need to replace the compressor? What failed?
You also need to replace the orifice tube, orings and schrader valves...well, if you're gonna do it right.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 14 Aug 2012, 05:20 am
Thanks for the replies guys.
I read through the previous discussion on DIY AC install. Must admit that it appears I'm out of my element on going ahead with this project. I installed my own AC system at home but had access to the vacuum pump at the time and some tech advice from the refrigeration techs I worked with. Guess I could probably rent a pump, if that's possible.
Anyhow, the AC tech at the local dealer said the valves inside the compressor were not keeping the pressure, which is why it was cycling on and off all the time. He also said there was a leak on one of the switches (high pressure?) on the compressor so that the gas had mostly all leaked out.( said when he tried to refill the system it all sprayed out from the leaking switch..Makes sense..?)
It's a 2003 so I'm reluctant to spend $1000 on it for a new AC, although the car is in pretty good shape.
Old 14 Aug 2012, 05:57 am
Personally I hate A/C and grew up without it, so don't miss having it. It's never really that warm in the UK that we "need" it rather than want it for bragging rights
However A/C is something that is only too welcome on a really hot day here(Canada) or there in the U.S, so I'm guessing you'll miss it before the year is out
It's an expensive repair, but if done correctly, and that's the important bit, it should last ya, well at least until the next time it breaks down again anyway
Good, easy replacement for factory audio system? Monkeyleg Sound and Security Forum 1 16 Sep 2009 10:55 am
New System in the PT! ucantcme General PT Cruiser Discussions 7 16 Oct 2008 03:38 pm
Complete Replacement of Sound System. Ideas? ecarfar Sound and Security Forum 5 28 Jun 2004 06:26 pm
