air bag light on all the time
Old 12 Aug 2012, 09:47 pm
Default air bag light on all the time
hi i have a 2005 basic pt . the air bag light stays on all the time now and i had it checked with a scan tool and got " passenger pretensioner circuit open"i don't know what it means. does it have anything to do with the seat belt? any help woulf be appreciated. thank you, jim hoysa
Old 12 Aug 2012, 10:09 pm
Default Re: air bag light on all the time
The code # will be helpful.
Old 12 Aug 2012, 10:52 pm
SpannerHound's Avatar
Smile Re: air bag light on all the time
On most cars with airbags you'll usually find a strain gauge in the seat, a switch in the seat belt buckle and a tensioner sensor in the belt roller. The strain gauge is usually calibrated for weight at the factory or recalibrated by the dealer if it's replaced. The belt tensioner sensor and buckle switch is usually replaced along with the seat belt. Sounds like your seat belt tensioner sensor is goosed
Old 12 Aug 2012, 11:11 pm
hi i think you will find out its your clock spring that went bad. if it is whats wrong your horn and cruise control is not working also i had to change mine to fix that problem.
Old 13 Aug 2012, 07:23 am
hi there is no code at all. it only says "passenger pretensioner circuit open". and can't get any more info. the horn and cruise work ok so that leaves out the clockspring. i can look at the seatbelt assembly but not sure what to look for. would i see a broken wire? thanks jim.
Old 13 Aug 2012, 09:06 am
reevescajr's Avatar
For whatever it's worth, the air bag light in my '03 turbo can take a long time to go out sometimes when I start the car. Something seems to be really sensitive to battery voltage, since it only happens after I haven't driven the car in a couple of days, or on cold winter mornings. Last time I had the battery replaced, it stopped doing it altogether for quite awhile.
But with the message you're getting, I think the recommendation to check the spring tensioner is spot on. Not sure what it looks like either, but I suspect there is an electrical connector involved. If so, the first thing I'd do is unplug it and plug it back in a few times, and also check for broken wires.
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
oil light on at start up beyound reg time. srebik Tech & Performance Forum 10 29 Dec 2010 11:17 pm
Engine Warning Light 3rd Time - 04 GT RD CHILI Tech & Performance Forum 10 23 Feb 2004 07:15 pm
Engine Warning Light 3rd Time - 04 GT RD CHILI General Turbo Discussions 18 12 Jan 2004 02:07 pm
