Ignition Issues
Old 13 Aug 2012, 06:37 pm
Default Ignition Issues
Amongst the other issues I have presented here, this is just another issue that is plauging my otherwise, lovely cruiser. Interestingly enough, I think I have this one figrued out, and I am wanting the group's oppinion before I order tonight.
My car will crank, the starter engages and there is not suspicion that it is anything but possibly the ignition switch or lock cylinder. When turning the key, it will go in the lock cylinder very nicely and will turn pass the electrical postions very easily, and you can turn it all the way to start position. When in the starting position is when it takes some "talent" to start. Once turned to the starting position, you have to press in and give it a little pressure for the car to start. Sometimes it will very easily and sometimes it takes multiple tries to start the car by pulling out the key, re-inserting the key, pressing in and turning to the starter position, giving a little pressure, and the car will start.
I think It is either the lock cylinder or the switch all together. Very cheap for both, even found them on Amazon ( links below for pictures). Just wanting some friendly advice. Thanks guys and gals.
Dave.
Old 13 Aug 2012, 06:41 pm
Default Re: Ignition Issues
The only concern I would have would be matching the key with the starter switch, I'm not sure where the match is made, that's one part of the PT's that I know nothing about. I know mine won't start without a matching keyfob, but don't know what keeps it from cranking.
Now as to your issue, it does sound like one or the other or maybe even both.
Old 13 Aug 2012, 08:28 pm
Dave.
There was a member that fixed one of these some on here!
Old 14 Aug 2012, 06:06 am
SpannerHound's Avatar
Smile Re: Ignition Issues
Sounds like worn switch contacts
Old 14 Aug 2012, 11:19 am
I figured the same. I ordered the ignition switch assembly and the lock cylinder just in case.
Dave.
Old 24 Jun 2013, 08:19 pm
randyincctx's Avatar
Exclamation Re: Ignition Issues
I have a similar problem except my PT will run and everthing works fine,only the 'door/key in' chime & radio display won't work unless I push the key cylinder in about 1/16"-1/8" then everything works fine.....UNTIL I stop pushing in on it......I'm sure some of you know exactly what is causing this little problem......I've trolled thru the threads,and this was the closest one I could find addressing my FUNKY issue! .....Anyone have some ideas,or suggestions???..... Thanks!
Aka:~KILLER~
Old 25 Jun 2013, 05:41 am
It sounds more like the switch than the key cylinder at the moment. One thing with a replacement key cylinder, is it will have a replacement key with it. If your car has code keys (light grey plastic, but mine have turned dark grey over time) it will not run with the replacement key.
Old 25 Jun 2013, 10:07 am
UptownSport's Avatar
I'd try this, Cheap at rock auto
Ignition : Ignition Switch Actuator Pin
(under 'ignition')
Old 25 Jun 2013, 10:23 am
Question Re: Ignition Issues
The key for my 2003 PT Cruiser Base is BLACK.....(only came with 1 from auction) IMAG0272.jpg
Aka:~KILLER~
Old 25 Jun 2013, 12:06 pm
mie is black as well. no chip inside.
2016 Kia Soul Plus Black
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
Key Won't Turn in Ignition twobits48 Tech & Performance Forum 6 29 Mar 2006 07:34 pm
