PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
tires,antilock brakes
Old 06 Oct 2001, 01:48 am
ricco cruiz ricco cruiz is offline
Default tires,antilock brakes
I want to put wide tires on the rear and keep narrow ones on the front
but, I was told I might have problems with the abs- the computer might
think theres slipage from the different tires.
Can I go with narrow / wide as long as they are the same size-is there
a tolerance that can be, like a 1/16 or 3mm or do they have to be
exactly the same size. And what about weight is that a factor?
Can you help, Thanx Ricco
Old 08 Oct 2001, 11:28 am
skylight's Avatar
skylight skylight is offline
Administrator
Shane from TireRack.com can answer all your PT wheels/tires questions.
his email is shane@tirerack.com he's knows everything about possible wheel/tire setups..
let us know what you find..
jody
Old 09 Oct 2001, 11:42 pm
well I've been reading his responses to people with the same question
and as long as it no more than 3% height difference between front and
back tires the abs should not be affected.
vB code is On
Close call with the brakes sawdust123 General Turbo Discussions 7 22 Oct 2005 01:13 pm
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
Brakes Squeak Konkeler Tech & Performance Forum 5 01 Jun 2004 12:40 am
Brakes - Turbo vs GT quicksilverdon General Turbo Discussions 11 16 Mar 2004 10:40 am
Brakes Artemis Tech & Performance Forum 6 14 Jan 2003 11:04 am
  Loans | Myspace Codes | Just Holden Commodores | Cheap Flights | Loans
