missing, smoking bad, no power
Old 14 Aug 2012, 08:50 pm
Default missing, smoking bad, no power
'01 limited with 97,000 miles. last week it started smoking white (heavy smoke) at start up and ran rough also you could smell gasoline at first, but after a few miles all symptoms would ago away. my wife had just filled up at a questionable fuel station so i thought maybe just bad gas.
last night about 3 miles from the house, car started bucking, and no power. i could slip the clutch/race the engine and sometimes it would "peter out" other times it would shoot out like a rocket but i'd shift to 2nd and it would happen again, any way, i got it home.
today i put known good gas in and car has a mis at idle and white smoking like james bond, i have code - p0203 - inj 3 control circut, but have no manual. anyone have any ideal what i should do next? how can i check this injector or do i just need to buy a injector?
thanks, mike
Old 15 Aug 2012, 03:21 am
SpannerHound's Avatar
Smile Re: missing, smoking bad, no power
I doubt that the injector itself is at fault, it could of course be clogged with crap, but I doubt it. You can swap the injector with one beside it to be sure. White smoke suggests head gasket to me I'm afraid. Get a compression test done and see how she looks.
Old 15 Aug 2012, 03:40 am
Default Re: missing, smoking bad, no power
Before you go any further, please check your oil and make sure it's not looking like a chocolate milk shake. If it is, just park it and go look for another car. If it's not, then there are a few guides out there to assist in troubleshooting issues like this. Let me know if you need a copy, too large to post here. PM or email me if you want a copy.
Old 15 Aug 2012, 11:23 am
also:
how do the spark plugs look?
how does the coolant look?
Old 15 Aug 2012, 11:28 am
oil is good, coolant is good, and no compresson with rad cap off, but eng is shake'n like it's trying to get out of the car.
i gonna replace plugs, i'll look at their condition and check compression, but i'm thinking it's the #3 injector deal
is there wiring to each individual injector that i can check for voltage/resistance, or Chromenut, is that what you had in mind?
thanks, mike
Old 15 Aug 2012, 12:41 pm
plugs look good - #1,2&4 light tan and dry, but #3 is wet with i think gas
intake - #1,2,&4 are wet and #3 is dry
looks like #3 is not doing something right
i unpluged inector, plug terminals look good, didnt have time to look at any other wiring today, gotta go to work, look some more tomorrow.
thanks mike
Old 15 Aug 2012, 02:04 pm
while it's apart, i would check to see if #3 is sparking before messing with the injectors. (just to rule it out, as it's easy to check) it could be lighting the fuel in the header instead, making your smoke show.
you might want to look down in the plug hole too, i saw a neon with a nickle sized hole in the center of the piston.
-just throwing a couple ideas out there.
Old 15 Aug 2012, 04:58 pm
If the injector is sticking open it can drown that cylinder and wash down the rings and will lower compression on that cylinder also. Ever use injector cleaner?
Old 15 Aug 2012, 09:39 pm
Did you do a compression test?
Old 15 Aug 2012, 10:16 pm
If you do a compression test you will need to add a squirt of oil to get a more accurate reading after all the fuel that been going in the cylinder.
03 tubo smoking prefesser357 General Turbo Discussions 23 11 Apr 2012 04:50 pm
Starter Smoking Swelve Tech & Performance Forum 4 14 Jan 2011 12:04 pm
rough idle and smoking jaci321 Tech & Performance Forum 3 23 May 2010 07:32 pm
Smoking Tires are amusing PlatinumTurbo Stage Turbo Kits 9 06 Nov 2006 12:20 am
MISSING AGAIN/HELP kromans Turbo Performance 8 24 Jan 2005 11:59 am
