Fog Light Issues
Old 16 Aug 2012, 12:55 pm
Default Fog Light Issues
I have an 03 PT Cruiser with fog lights I recently bought, I just figured out how to turn the fog lights on and they dont come on. i checked the fuse and the bulbs and all is good. Anybody else have this issue and if so any ideas on how to fix it? Thanks
Old 16 Aug 2012, 01:01 pm
Default Re: Fog Light Issues
You probably have a burnt out multi-functions switch. That's the stalk on the left side that turns the fog lights on. It's pretty common problem. You can try fixing it yourself if your handy with tools or just replacing the switch which runs about $70.
Old 16 Aug 2012, 01:05 pm
How would i go about fixing it? i removed the housing and removed the multifunction switch and it looks almost brand new?
Old 16 Aug 2012, 01:23 pm
Here, you can read through this:
How to Repair the Multifunction Switch w/ Pictures (Fog Lights)
BTW, it was the No#8 fuse in the interior fuse box that you checked, right? Usually, new owners find that the fuse has been taken out because the fog lights stay on all the time when the switch goes bad and to stop the lights from coming on, they pull the fuse.
Old 16 Aug 2012, 01:51 pm
Smile Re: Fog Light Issues
huge help i will try that thank you
Old 16 Aug 2012, 01:53 pm
yes i checked the #8 fuse it was dirty nut not blown so i cleaned the fuse, but that didnt fix the problem. i am going to try repairing my multifunction switch next like you suggested. thanks again
Old 17 Aug 2012, 04:31 pm
update, i took it apart and cleaned it unstuck the one part put it back together and the fog lamps came on when the switch was off and headlights didnt work. took it apart again and put it back on and headlights worked but again no fog lights. i am guessing i just need to replace the switch. any suggestions?
Old 17 Aug 2012, 07:02 pm
Did you read all the pages on the link? Did you get far enough taking the switch apart to see the offending little micro switch that goes bad and allows the fogs to stay on when a part burns up?
Old 17 Aug 2012, 08:54 pm
I saw that but wasn't sure If that applied to mine since they don't say on. They came on once and don't work at all still. I will take mine apart again and check that. Thank you
Airbag light issues jmack General PT Cruiser Discussions 18 15 Jan 2015 12:34 pm
2004 PT cruiser having engine light issues echillie1 General PT Cruiser Discussions 20 30 Dec 2011 12:19 am
tail light water issues Dino General PT Cruiser Discussions 4 26 Apr 2011 07:58 pm
Fog Light Issues meandean Exterior Accessories Forum 14 25 Mar 2010 04:36 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
