Looking for help with radiator fan diagnosis
Old 18 Aug 2012, 12:44 pm
Default Looking for help with radiator fan diagnosis
First post here. I've been working on my sister's 2002 PT non-turbo and using the forums here for help.
The radiator fan has stopped working, high and low. The fuse is good, the high and low relays work. I read on here and a few other places how PT's can have this problem from loose or burnt wiring. Checked the wiring in the PDS and it all looked fine.
The connector at the fan is getting voltage, although the meter is reading about 29 volts. The sockets for the 2 relays each show about 24 volts across the power parts of the socket (labeled 85 & 86 on the relays).
I'm no automotive electrician, but at least I see the relays are getting voltage, and the wiring is sending voltage at the fan connection. So that's just a dead fan right?
And if it is, I know the service manual says you have to take the whole radiator out to get at the fan, but it's just held on with 6 bolts, and maybe I have to take the lower radiator hose off, and then I can just pull it out the bottom. Anyone ever done it that way?
Old 18 Aug 2012, 01:11 pm
Ray_Dockrey's Avatar
Default Re: Looking for help with radiator fan diagnosis
This will help you. Comes out the top.
Removing the fan and housing 01-05 PT
Old 18 Aug 2012, 01:38 pm
mdfrodolives's Avatar
There are numerous threads on this forum that point directly to the fan, itself, as the primary reason why the PT fan doesn't work.
This will be another.
BTW, that "How To" is spot on for your 2002.
Have fun,
Tim
Old 19 Aug 2012, 02:27 am
I just added a complete section to someone's post earlier this week. Search the forums to find it, it has all kinds of info on troubleshooting the fan.
Old 19 Aug 2012, 10:07 am
+! to replacing the fan motor or assembly. Very unlikely to be anything else.
The radiator fan [again] bogaz Tech & Performance Forum 43 23 Aug 2011 06:43 pm
Timing belt diagnosis Cliffordpoe1 Tech & Performance Forum 11 21 Jan 2011 01:34 pm
Overheating diagnosis shammesfah Tech & Performance Forum 1 09 Sep 2010 09:32 pm
radiator fan bbromero Tech & Performance Forum 4 08 Jun 2010 03:58 pm
Overheating Diagnosis Gomanngo Tech & Performance Forum 4 17 Jul 2009 11:05 am
