2009 a/c wiring diagram
Old 18 Aug 2012, 04:09 pm
Default 2009 a/c wiring diagram
I am looking for a wiring diagram for my daughters 2009 PT Cruiser Touring edition. A/c is cycling off at idle causing rough idle. I understand it could be the fan motor. I assume it is a 2 speed motor. I see 3 conductors to motor. Is center ground? Other 2 12 volt input? Is high speed input 12 volts on one side and low speed input 12 volts on other side? Do they both input 12 volts at the same time?
Thanks.
Old 18 Aug 2012, 04:45 pm
Ray_Dockrey's Avatar
Default Re: 2009 a/c wiring diagram
Center pin is ground. One side is the high speed fan and the other is low speed. Wiring is all the same from 06-10. They do not input at the same time. The relays sit right beside the fan and are mounted on the shroud. A new fan will come with new relays.
Old 19 Aug 2012, 07:58 am
Thanks for the input. I will check it out this morning and update what I find.
2001 pt cruiser stereo wiring diagram Koolaid2012 Sound and Security Forum 2 30 Sep 2015 02:38 pm
Wiring Diagram clint21anne Tech & Performance Forum 10 24 Jun 2012 11:44 pm
PCM wiring diagram PTcruzer02 Tech & Performance Forum 0 10 Nov 2009 09:35 am
Need Radio Wiring Diagram 2006 Tintellaar Sound and Security Forum 4 02 Jul 2008 10:45 pm
Radio Wiring Diagram for Dummies TexasPriest Sound and Security Forum 2 25 Mar 2008 09:55 pm
