Stabilizer Link Missing
Old 19 Aug 2012, 08:34 am
Default Stabilizer Link Missing
So the last item on my list of stuff to investigate and fix on my newly acquired PT was this clunking noise from the front end over bumps.
Well, the problem is fairly obvious -- the driver side stabilizer link is missing and the sway bar is just hanging out there wiggling. Not sure why a previous owner would do this.....
All the mounting hardware seems to be gone - whatever nuts bolts would go there, there is nothing on the control arm but a hole.
If I buy a link, I am not thinking it will come with mounting hardware. Anyone know where I can get part numbers for what I need beyond a new link?
Yes I will replace the sway bar bushings too since they are undoubtedly worn from the car being left in this condition. I will probably do the passenger link also.
Old 19 Aug 2012, 10:53 am
xwing777's Avatar
Default Re: Stabilizer Link Missing
These are made just like the factory pieces MEVOTECH Part # MS25800 and you will need 2 of them to do both sides.
You can get the kit at any autozone, advance, etc..BUT they are semi-universal and use a bolt that can hit the axles when you jack the car up.
Old 19 Aug 2012, 12:59 pm
rcktpwrd's Avatar
Now would be a good time to upgrade to poly bushings. Search for Energy Suspension parts, you can get a kit that comes with the end links and sway bar bushings specifically fit the PT.
Joel
www.rcktpwrd.com
Old 19 Aug 2012, 01:10 pm
SpannerHound's Avatar
Smile Re: Stabilizer Link Missing
Yup, as xwing said, do both sides at the same time. You may need to hacksaw off the existing one, quite often the threads are so badly stretched that the locking nut will refuse to come all the way off the bolt, it's a 14mm as I remember but nothing a hacksaw, spanner(wrench), and a socket can't easily cope with. You will also find it a lot easier to fit the new ones if you can swing the anti roll(sway) bar down out of your way. Just make sure that you tighten the lock nut all the way to the end of the thread on the bolt which can be quite long on the universal aftermarket parts. I usually cut off the excess bolt to about 1/2" beyond the nut to stop it picking up crap from the road, but it's not really an issue if you want to leave it on. It's one of those pain in the whatsit jobs to do, but easy enough to remedy as long as you stick the vehicle up on axle stands. I wouldn't attempt this with the car only on a Jack etc as you will be pulling it about and may need to lay underneath it etc so you'll need the ground clearance as well
Old 19 Aug 2012, 01:47 pm
rcktpwrd's Avatar
Arrow Re: Stabilizer Link Missing
here is one place to get the parts:
Energy Suspension 5.8105 Front Sway Bar End Links - Dodge Neon / PT Cruiser
Energy Suspension 5.5153 Front Sway Bar Bushings - 24mm
Joel
www.rcktpwrd.com
Old 19 Aug 2012, 04:20 pm
xwing777's Avatar
The one i posted from rock auto IS poly and is made just like factory
Old 01 Sep 2012, 03:40 pm
Ebay sells these kits! Good luck! You can find free ship too!
Old 01 Sep 2012, 09:43 pm
HELLO. Recently ordered a pair from ROCK AUTO, Also they have several brands to choose from.
Front Stabilizer Bar Bushes and End Links PigFarmer Wheels, Tires, Suspension 1 16 May 2012 09:18 am
The Missing Link PiperGeorge General PT Cruiser Discussions 15 18 Jul 2009 02:14 pm
Voltage Stabilizer djpadko Tech & Performance Forum 6 13 Aug 2008 03:24 am
Petition now online - Stabilizer Bar deletion Dalite General Turbo Discussions 26 27 Jul 2003 04:25 pm
Stabilizer Bar GTPT General Turbo Discussions 1 04 Jul 2003 01:57 am
