Burp Free Mod
Old 19 Aug 2012, 08:19 pm
Bluej's Avatar
Default Burp Free Mod
I have a 2001 non-turbo automatic that seems to fit the description on this link to a tee. Has anyone tried this and does it work? I tried doing a search for this and could not find anything. TIA
MX-5 PT Shift 'Burp-Free' Mod
Old 19 Aug 2012, 08:32 pm
Default Re: Burp Free Mod
YES, it works. Myself and countless others have done this mod. Definite improvement when going from 1st to 2nd. Eliminates and hesitation and gives a clean crisp shift.
Old 20 Aug 2012, 03:39 am
Bluej's Avatar
Thank you. Wanted to be sure before I started cutting...
Old 20 Aug 2012, 06:35 am
mdskinner731's Avatar
just did the "burp stop" mod on my pt friday after work!!! all i can say is wow what a difference!!
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 20 Aug 2012, 09:09 am
jrs61282's Avatar
Any chance it'll work on a 2nd 2008
xDVLSADVOCATEx
Old 20 Aug 2012, 09:50 am
Ray_Dockrey's Avatar
Nope. Only on the 2001 and 2002's.
Old 20 Aug 2012, 05:49 pm
I have an 03 does anybody know if there is a way to do the burp mod to an 03?
Old 20 Aug 2012, 05:52 pm
The Technician that thought up the Burp-Mod said only the 2001 and early 2002 models could use the burp-Mod because things changed after that. Like the EGR was taken away among other things.
From the Burp-Mod site:
This modification does not work on any 2003 model year PT's since there is no wire input or output for the newly designed 2003 PCM. The 2003 PCM seems to have taken over some of the TCM controls. This function is likely an internal pre-programmed one.
Old 20 Aug 2012, 06:05 pm
Had that feeling. Just trying to find a way to make mine shift smoother. It occasionally bucks
Old 21 Mar 2014, 10:54 pm
randyincctx's Avatar
Unhappy Re: Burp Free Mod
I just learned about this mod today,and then immediately found out it won't work on my PT Cruiser(2003!).....But,there may be some '01 & '02 PT owners that are new to the forum,and might be able to benefit from the mod.
Aka:~KILLER~
MX-5 'Burp -Free' Mod. Procedure IRPT Tech & Performance Forum 96 29 Jul 2015 07:46 am
Burp my Clutch? mikelikestobike Tech & Performance Forum 4 22 Jan 2011 05:06 am
MX-5's 1-2 Shift burp mod TaylorMade Tech & Performance Forum 1 05 Aug 2004 02:15 pm
Second Gear Burp Bloxstudios Tech & Performance Forum 5 25 Feb 2004 09:30 am
Whats the "Burp"? BUBBA-KONA Turbo Performance 4 28 Sep 2003 01:02 pm
