no dash lights
Old 19 Aug 2012, 09:49 pm
crazyptguy's Avatar
Default no dash lights
went to put new dash led bulbs in my cluster and half worked changed the polarity on the non working and they worked wife said they were too dim and wanted the old ones back in. after replacing the old back in the cluster none worked tried the polarity switch and still no working bulbs the bulbs worked when i took them out any ideas?
03 Pt Woody Classic 116k miles Rebuild project.
Old 19 Aug 2012, 09:56 pm
needmoretoys's Avatar
Default Re: no dash lights
Did you check the fuses and the dash dimmer switch?
Old 19 Aug 2012, 10:22 pm
crazyptguy's Avatar
dimmer switch check fuses check going to try in the am again getting flustered
Old 20 Aug 2012, 08:05 am
Read on here less suppose to be brighter. So maybe post what ones you have. Maybe guys who have done this mod can give you some good advise. Curious as to what is up myself?
Old 20 Aug 2012, 10:57 am
crazyptguy's Avatar
superbrightleds are what i used but i got them in red and they all worked but just werent very bright seemed like the light wouldnt make it thru the green layer of the numbers . the needles and any red areas of the gauges were very bright and the high beam bulb is very bright . is there something i have to do to make the numbers brighter ? the original bulbs wont light at all but the red ones do
Old 20 Aug 2012, 06:19 pm
PM Rocketman, He has done the mod and may know others.
Dash lights IamN00bz General PT Cruiser Discussions 7 13 Apr 2012 11:22 am
no dash lights or head lights suescruiser Welcome New PT Cruiser Members 0 14 Feb 2012 10:44 pm
Dash lights and tail lights out ab1 Tech & Performance Forum 2 01 Feb 2012 04:34 pm
05 dash lights. wompus General PT Cruiser Discussions 9 29 Dec 2010 04:14 pm
Dash lights again rpernicano General PT Cruiser Discussions 2 18 Nov 2010 08:06 pm
