Spit & Sputter
Old 20 Aug 2012, 02:11 pm
Default Spit & Sputter
My 2005 PT Cruiser is spitting & Sputtering when I bring it to a stop and the AC is running. When I turn of the AC the engin runs fine. Any Ideas?
Old 20 Aug 2012, 02:49 pm
Default Re: Spit & Sputter
no need to post twice for the same issue. sometimes it takes a while before someone comes in to help. that being said, the solution to your problem is probably simple.
radiator fan. a very common problem with the pt cruiser. it's a 2 speed fan, high and low, and chances are either one or both of the speeds has worn out contacts.
look in the tech part of the forums under "how to" and you'll find posts on how to check your fan to see if it is running correctly as well as how to replace the fan. you can get a new fan on rockauto for less than $100. i believe the Dorman has a lifetime warranty.
vacuum readings and sputter harveje General PT Cruiser Discussions 4 04 Aug 2012 04:00 pm
2008 PT Cruiser shaking & sputter help! Lilsispatrick Tech & Performance Forum 7 05 Jun 2012 12:25 pm
shudder and sputter when in 4th gear pppt03turbo General Turbo Discussions 2 25 May 2012 08:35 pm
04GT Cough, Sputter, Die!! JPMS GT General Turbo Discussions 1 11 Jun 2004 01:04 pm
...high rpm sputter... earringboy Turbo Performance 4 25 May 2003 08:48 pm
