Custom Wheels
Replace Fuel Pump 06 Turbo
Old 20 Aug 2012, 06:11 pm
Default Replace Fuel Pump 06 Turbo
Anyone know the steps required to change out the fuel pump on an 2006 PT Cruiser with a turbo engine?
How long should it take? etc?
Thank you in advance for any assistance on this matter. :-)
Old 20 Aug 2012, 06:22 pm
Default Re: Replace Fuel Pump 06 Turbo
The pump is inside the fuel tank, so you'll need to drop it.
Old 20 Aug 2012, 06:47 pm
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 20 Aug 2012, 10:43 pm
Chromenut's Avatar
It's actually not difficult, but a PITA to do. Labor intensive, but again, not difficult. We rented a booth at a local shop with a lift, raised my friend's PT and dropped his tank. His fuel filter, which happens to be part of the pump assembly, was totally clogged up with crap.
Took us about 4 hours to get it done. Two of us doing the work. Messy as hell, but still wasn't too bad.
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
Please visit the Tech Docs Library and you'll find many of your answers!
Old 21 Aug 2012, 01:08 pm
I dropped the tank on my daughter's 04 on Sunday and will put the new pump in tonight. My pump is fastened in different than in the picts that Crewzin posted. It had a metal ring the fits tight under some tabs when turned in place. If you need to drain your tank to get it out, on mine I had to fully take it out, put it on some sawhorses and put a screwdriver in the fill tube to open a valve in the tank. Not a bad job, if it goes in as easy as it came out it would take a total of about 2 hours.
Bob
Old 21 Aug 2012, 01:47 pm
as long as its drivable, drive until the 2nd set of 'low fuel' warning chimes comes on. This will leave you with about 2-3 gals of fuel remaining when dropping the tank. If you're doing it alone in the driveway like i did, try not to press to hard on the center of the tank where the float arm rests. You dont want to bend it
'03 GT base w/177k and a 2 speed auto & powered by a hybrid MOPAR S3
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Bad fuel pump? Jules88 Tech & Performance Forum 8 28 Jun 2012 10:11 am
water pump replace question. fabreezai Tech & Performance Forum 4 13 Jan 2012 08:49 pm
Cost to replace power steering pump? djfox1 General Turbo Discussions 4 24 May 2009 07:42 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 05:08 pm
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
