cooked charging system wire(s)
Like Tree3Likes
  • 2 Post By soyomb
  • 1 Post By UptownSport
Old 20 Aug 2012, 08:57 pm
Default cooked charging system wire(s)
my wife's 02 pt cruiser charging system went out over the weekend... I replaced the generator/alternator (not too bad if you cut off the exhaust ear on passenger side under the heat shield, and pull it through the top), and put in a new optima red top.... I did find the wire coming from the starter to the alternator, and its cooked. where can I find a replacement? I know the wire should go from dark green to black with white stripe, but its cooked, and useless.....
thank you in advance!
p.s. this site has been very useful thus far!
Old 20 Aug 2012, 11:41 pm
SpannerHound's Avatar
Smile Re: cooked charging system wire(s)
Cheapest place would be a car breaker(auto wreckers)
Old 21 Aug 2012, 12:40 am
Default Re: cooked charging system wire(s)
I have tried the closest yard with a pt is nearly 110/177 miles/km away, and wont be able to drive there until sunday..
is there any other cars that might share the pt cruiser power train setup?
Old 21 Aug 2012, 02:12 am
you could fabricate your own. get some wire at a hardware store of the same gauge and solder and crimp connectors on the ends. use the cooked wire as template for the length. should be tons cheaper and less on gas.
CREWZIN and ptpinto like this.
Old 21 Aug 2012, 03:16 pm
UptownSport's Avatar
There's instructions in the FSM (Just, looked though, can't find them for you) on fusible link replacement.
FSM lists a 6 gauge wire, with a 10 gauge fusible link. You'll have to duplicate link length.
ptpinto likes this.
Old 21 Aug 2012, 09:00 pm
Thank you everyone! I had no idea what size that fusible link had been prior to it grounding I assume?(I placed a temporary fuse box with a 30amp fuse in line, and it Pope immediately) I'm off to the parts store right now!
Charging System Help RMoore Tech & Performance Forum 21 27 Aug 2012 09:28 pm
Charging system robmet55 Tech & Performance Forum 4 22 Jun 2012 11:18 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
Charging system issues Murdered Tech & Performance Forum 1 12 Feb 2011 07:37 pm
Looking for charging system mods oldcoach General PT Cruiser Discussions 0 27 Oct 2007 05:16 am
