Need Help - Knocking/Clunking only when coasting??
Old 22 Aug 2012, 03:00 pm
Default Need Help - Knocking/Clunking only when coasting??
Ok I have got one for you. 02 PT with 106k. This has got me stumped. It started last night I noticed merging off the freeway that I get a steady rhythmic (according to speed) "knock" or "clunking" coming from up front. It only happens when my foot is off the gas and it goes away when I apply the brakes, returns when I let go of the brakes. Not so much a vibration though as I can't really feel it in the floor (yet). Honestly it sounds like a flat tire but is not. Does anybody have a clue to what this might be? Thank you for any help you may have.
Old 23 Aug 2012, 01:09 pm
Default Re: Need Help - Knocking/Clunking only when coasting??
Any guesses?
Old 23 Aug 2012, 01:23 pm
I'd start with the breaking system. Also check to see if it is different when you steer right or left.
Old 23 Aug 2012, 03:45 pm
After a lot of searching, I am starting to think it is one of the front wheel bearings. Is there any way to diagnose which side could be bad? I cannot tell while I am driving.
Old 23 Aug 2012, 04:12 pm
Find a curvy road, or a big empty parking lot. Do "S" turns...that will load the bearings seperately. If the noise goes away when turning right, it is probably the right front wheel bearing. If it goes away turning left, uhhh, I bet you can figure that one out.
Unless, of course, I have it backwards. Which could be a real possibility!
Rob
Old 23 Aug 2012, 04:51 pm
Yea Rob, I think it's the other way round. Taking the pressure off the right bearing when turning left would take away any bearing noise on the right.
Old 23 Aug 2012, 07:53 pm
Not arguing with you...just trying to clear it in my mind. If you turn left, doesn't that put more weight on the right side wheels, thue "loading" the bearing more?
Or do I need another beer?
Rob
Old 23 Aug 2012, 08:00 pm
Thinking about it more, your right, too much ice cream for desert. Turning left puts weight on the right.
Old 23 Aug 2012, 08:15 pm
Change one, may as well change the other!
clunking noise?? Dino General PT Cruiser Discussions 23 23 Apr 2013 01:36 pm
please help clunking and few other questions wreksta Tech & Performance Forum 0 15 Sep 2009 05:04 pm
Weird Coasting Sounds decembersonata General PT Cruiser Discussions 3 02 May 2005 01:06 pm
Coasting in Neutral...BAD? crazie.eddie General PT Cruiser Discussions 10 10 Sep 2004 03:30 pm
clunking 5 speed ote69 General Turbo Discussions 6 20 Oct 2003 05:04 pm
