03 GT trans issue...weird one
Old 23 Aug 2012, 08:19 pm
Default 03 GT trans issue...weird one
I just picked up an 03 PT from a friend. It's our second one now. My daughter drives an 01. He stated when we spoke on the phone about it that the trans needed to be rebuilt or replaced and was not drivable so naturally I scored the car cheap.
When I picked up the car tonight (with a trailer) I come to find out the car has absolutely no gears forward or backward whatsoever. That's not the strange part although some blown transmissions will still give ya something when cold.
What's weird about this one is this...It has no park either!
What the heck is that all about?? I've never heard of a blown trans losing park. Is it possible that there's a more reasonable explanation for this and it's not a bad trans??
any thoughts?
Thanks,
Tony
Old 23 Aug 2012, 08:24 pm
Default Re: 03 GT trans issue...weird one
Sounds like a fly wheel!
Except for the park gear.
Old 23 Aug 2012, 08:48 pm
Yeah, that's what's got me stumped is the no park thing. otherwise I'd say a flywheel or input shaft ot something of that nature. He said it just went boom out of no where and suddenly...nothing. No gears and no park. A complete disconnect. Incidentally, no noises while it's running and no check engine light.
Old 23 Aug 2012, 09:32 pm
Must have broke a hub in the park paw area.
Old 23 Aug 2012, 09:36 pm
Would that cause no forward or reverse movement at all as well? Seems awfully strange that this happened as he was pulling out of the mechanic's lot having just spent close to $300 on rear shocks and battery cables. (which he was ripped off for by the way)
Old 24 Aug 2012, 02:45 am
WTHeck is that?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 24 Aug 2012, 05:31 am
Better yet, how does that break when doing less than 10mph?? This situation happened while pulling out of a parking lot and the car never made it past the double yellow line to the other side of the street. Still stumped on this one.
I wish I knew where to begin with this diagnosis and repair but I'm clueless
Old 24 Aug 2012, 07:12 am
Ray_Dockrey's Avatar
I am reaching here but you said they replaced the battery cables. Is it possible that they did something to the shift linkage? And it is stuck in neutral? The shift linkage is right there by the battery in the area they were messing in.
Old 24 Aug 2012, 07:29 am
Originally Posted by OurPTGT View Post
WTHeck is that?
It's a mechanical lever that locks the trans. from turning so your pt wont role off.
Old 24 Aug 2012, 07:42 am
Yes it seems to be stuck in neutral but it did drive out of the bay and atleast across the street before the bang and now nothing. No forward, reverse or park. Will check shifter mechanism
weird a/c issue bogie2929 Tech & Performance Forum 2 05 Aug 2012 09:54 am
Weird Cooling Issue TurboDucky Tech & Performance Forum 3 31 Dec 2011 01:40 pm
Weird Door Lock Issue (different from others I have seen here) justme General PT Cruiser Discussions 0 10 Aug 2011 10:33 am
Weird Foglight Issue... derek02PT Tech & Performance Forum 2 07 Aug 2011 02:52 pm
Weird issue Opiate General PT Cruiser Discussions 4 09 Aug 2008 10:05 pm
