Runs eratic at low speed
Old 24 Aug 2012, 10:23 am
Default Runs eratic at low speed
Hello:
2001 LTD, and when I drive around 10-15 mph, the engine runs a little eratic, it is hard to describe, sluggish may be the word.
I have put in new plugs, new plug wires, new air cleaner.
I don't get any codes.
I have recently installed a new trans solonoid, could this be the problem?
tnx...Rotty
Old 24 Aug 2012, 10:52 am
Default Re: Runs eratic at low speed
Well, according to the Internet, you have to very careful when changing out the the trans solenoid pack because and dirt surrounding the old pack might find it's way into the clutch circuits or valve body. The whole area should have been cleaned before removing the old pack. Hopefully you did that and nothing got into the trans to make it act the way you describe.
Old 24 Aug 2012, 11:32 am
Yes, I was anal about keeping that area clean.
I think it's the engine that seems to run badly at this speed. I am going to put the tranny into a lower gear and see if it's the tranny not downshifting at that reduced speed.
Any way to retrain the solonoid? Is there a program that would load up to a solonoid and then one doesn't have to train it through driving? The reason I ask is because both myself and my wife drove the car after the solonoid replacement. Could it have confused the re-training effort?
Old 24 Aug 2012, 11:34 am
If there is, you'd have to go to a dealer and pay to have it done.
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
It runs again Arizcruiser Tech & Performance Forum 3 21 Jul 2011 12:54 pm
Fan Runs But No Air Comes Out tomgrigsby General PT Cruiser Discussions 4 20 Apr 2011 03:53 pm
I got the runs.... crazie.eddie Tech & Performance Forum 7 19 Oct 2004 03:59 pm
Says runs Hot stirfry General PT Cruiser Discussions 8 01 Apr 2004 11:25 am
