Overheating Problem on My 2003
Old 25 Aug 2012, 02:46 pm
Red face Overheating Problem on My 2003
Dear PT Cruiser Lovers,
While I am new to the forum, I have had my PT Cruiser since 2003 and it has become a family heirloom with a commitment to hand it down family member by family member until it falls apart. In this regard, I have a desire to keep it in top notch shape which brings me to the problem.
It appears that the intermittent overheating problem is nothing new to many of you and I need your help. I have had a new radiator and cap installed as well as a new thermostat. The cooling system was flushed and new water and antifreeze put in. It stills overheats intermittently. By my own process of deduction it looks like it now must be the fan motor and/or the PCM module. Here are three questions:
1. Is this a logical conclusion?
2. If it is the fan will one of the aftermarket fans I see when I Google search okay to buy or should I by an OEM part?
3. Do you think it could be the PCM module?
Sometimes it will overheat and sometimes not , so any help would be much appreciated.
Thanks,
ProfessorB
Old 25 Aug 2012, 02:50 pm
Default Re: Overheating Problem on My 2003
yes, a logical conclusion. get a dorman fan at rockauto.com. i believe they have a lifetime warranty.
Old 25 Aug 2012, 03:24 pm
Ray_Dockrey's Avatar
It's not a GT is it? They use a different fan that is very expensive. Second, what makes you suspect the fan. Can you here the fan running when the AC is on?
Old 25 Aug 2012, 03:49 pm
mdfrodolives's Avatar
If you haven't replaced the fan, I would suspect that. You've replaced everything else.
If you have a non-turbo, check both fan speeds, using the Sticky on the first page of this forum (Tech and Performance).
Tim
Old 28 Aug 2012, 07:32 pm
Thanks guys. I will go ahead and replace the fan and let you all know.
Regards,
ProfessorB
2003 PT Cruiser overheating AJFSHRMN Welcome New PT Cruiser Members 3 15 Apr 2012 06:59 pm
2003 Overheating after many repairs dazy1331 Tech & Performance Forum 12 30 Mar 2012 11:34 pm
2003 pt cruiser overheating madcop811 Southeast PT Forum 33 06 Feb 2012 10:55 am
OVERHEATING 2003 on streets oldorange Tech & Performance Forum 4 04 Sep 2010 11:28 pm
2003 pt overheating yousai General PT Cruiser Discussions 5 08 Aug 2010 08:24 pm
