Added a small amount of the wrong tranny fluid.
Like Tree3Likes
Old 25 Aug 2012, 09:49 pm
Default Added a small amount of the wrong tranny fluid.
Hi, I have a 2007 PT Cruiser and noticed the tranny fluid was a little low(I know I should get it checked for a leak I've just been putting it off).
I had my friend pick up some fluid for the me the other day and was very specific about what type, which I even wrote down. Me, being the absent minded dolt that I am started adding it without even giving it much of a glance. I got about a third of a quart when I noticed it was Type F ATF.
Can I expect any adverse effects from this?
Thanks, Jim.
Old 25 Aug 2012, 09:56 pm
Default Re: Added a small amount of the wrong tranny fluid.
Depends who you ask. Might be a good time to get it serviced and that leak fixed?
Old 25 Aug 2012, 10:03 pm
Sure, but I don't need to flush the transmission?
Old 25 Aug 2012, 10:08 pm
If you didn't add more than a half a quart I wouldn't worry about it. But there will be though's who will have a cow.
Old 26 Aug 2012, 07:05 am
rcktpwrd's Avatar
I agree with Busted I wouldn't worry about that small amount of the wrong type of ATF...
Joel
www.rcktpwrd.com
Old 26 Aug 2012, 07:13 am
i added less than one quart of type F to my lincoln mark 8 and after a couple blocks the trans started slipping very bad and the car never ran again.
Automatic Type F - it ruined the nicest car i ever owned. i bought generic stuff at the hardware store i thought they just spelled it out. learned the hard way. DON"T BE ME.
this was with less than a quart on a trans that's bigger and stronger than yours. if i were you i would drain it and flush it and then refill it and punch your friend in the throat
Old 26 Aug 2012, 07:50 am
The only way these will happen is you already have issues any way. If your adding fluid you have a problem, that left unresolved will cause the very problem described here. If your fluid is continually getting low, you are putting ware on the weakest clutch pack. Eventually you will add fluid and it will slip. But not from the fluid you added but from the ware from all the previous times you were low on fluid. The small amount you added won't change the chemical make up enough to do any thing even if you left it in. But with a leak your eventually will shorten the life. Then you will be writing here or some place saying how the wrong fluid ruined the best car you ever had. Don't be that guy! Fix the leak and change the filter and fluid. It is probably time for that anyway.
Old 26 Aug 2012, 08:49 am
According to valvoline's site and FAQs, the only source I could find quickly on fluid differences, Type F is a non-friction modified formula, whereas ATF+4 (and also Dexron/Mercon) are friction modified.
Friction modification is done to aid the clutches -- friction modifiers reduce the surface friction (make it less slippery). Transmissions designed to have the tranny fluid less "slippery" need the friction in the fluid, else the clutches do not have the friction required to hold them as tight as they should be, and over time will start to slip, and once slippage happens (actually a little before you notice it through drivability) that accelerates wear on the clutches.
That being said, adding just a little type F is better than running without the correct amount of fluid. For a short period of time, no problem. I'd simply change the fluid and filter as soon as you can.
Should be no need to flush since the problem is that fluid doesn't have the friction modifiers you need -- if it were the converse I'd flush.
Of course, while you are servicing find the leak and fix it. No one ever checks tranny fluid as they should, so the first time you find out it is low is when it is already slipping or slow to go in gear, etc. and damage has already happened at that point. And if you know it doesn't leak you don't really need to check or worry about the fluid too much and checking every 6 months is fine.
Busted_PT likes this.
Old 26 Aug 2012, 10:00 am
OMG I having a "COW"
The dilution factor is insignificant to cause any harm to the transmission. The natural response is to change out the fluid. The reality is even if you did there will still be some Type F fluid remaining. There is no reasonable way to completely change out and replace all the fluid while the transmission is still assembled. You could connect a fluid pump and cycle the proper ATF through the transmission, but this would take at least twice as much fluid as the transmission holds and even then it may not completely remove and replace all the transmission fluid? If anyone has ever looked at a cross section of a torque converter and the valve body you would understand what I am talking about referencing anything using the words "flush" and "completely" with an assembled transmission.
NOT exactly PT specific but will suffice for the purpose of generalized information.
Basic Torque converters:
Basic picture of a valve body:
On my personal PT I run an additional transmission fluid cooler and a temperature controlled fluid pump. So changing out the fluid on my PT is much more easier and more thorough.
Old 26 Aug 2012, 11:54 am
[QUOTE=NitroPT;444771]OMG I having a "COW"
See, I told you someone would!
Changing tranny fluid hidinginparadise Tech & Performance Forum 7 23 Aug 2011 06:13 pm
changing tranny fluid bluemonster General PT Cruiser Discussions 1 09 Jan 2011 01:44 pm
Antifreeze and Tranny Fluid? tbandab Tech & Performance Forum 2 28 Jun 2010 10:02 am
Overfilled tranny fluid Gamadonis Tech & Performance Forum 5 02 Mar 2010 08:09 am
amount of boost? ptgt Turbo Performance 3 30 Sep 2003 01:44 am
