Vacuum Issue
Like Tree3Likes
Old 26 Aug 2012, 02:08 pm
Cool Vacuum Issue
My check engine light is on. I went to Autozone to get codes. They gave me: aa1,aa2, aa3, aa4. One of the parts guys told me the common problem on this 2007 Pt Cruiser is the Esim (not sure if that is spelled right.) valve goes bad. He said it is under the car near the big black box near the gas tank. I jacked the car up and dont see what he is telling me. Any suggestions?
Old 26 Aug 2012, 02:15 pm
Ray_Dockrey's Avatar
Default Re: Vacuum Issue
Those codes don't make any sense. Do the key dance to get the actual codes. The guy you talked to doesn't know what he is talking about. Come back with actual codes and we can help.
XtrmDC2 and Badglas like this.
Old 26 Aug 2012, 02:28 pm
PeteyGT's Avatar
And maybe introduce yourself while you're at it.
Badglas likes this.
Old 26 Aug 2012, 02:41 pm
The codes are bogus, the vac pump he's talking about is on the gas tank. But without the right codes it's a crap shoot. Check your vacuum lines. Start with the big ones first, follow them to there conclusion were possible.
Old 26 Aug 2012, 02:47 pm
Danny I am going to pass on this one.
Just chalk up an additional post for me catching up to you and BTW that is under engine code aa5 for forum posting info.
Old 26 Aug 2012, 04:39 pm
ka-ching
Old 26 Aug 2012, 06:01 pm
Thanks guys, I will get the actual codes and get back to you.
Old 30 Aug 2012, 06:42 pm
I got the code P440
Old 30 Aug 2012, 07:52 pm
Default P0440
Most of the time it is your gas cap sealing capacity has deteriorated and will not completely seal properly. They are cheap enough just buy a new one. You can have yours tested but I am sure that's what the results will be. Most every thing else would need an experience level to inspect and check all having to do with your emissions system. Given that your PT is a 2007 it is not likely anything else but not to rule them out. Remember to clear the codes after any fix or repair.
Old 30 Aug 2012, 08:18 pm
Thanks, I will replace the cap
vacuum leak clsals Tech & Performance Forum 11 21 Apr 2015 09:21 pm
Vacuum leak? Mulligandog Tech & Performance Forum 6 25 Feb 2011 09:00 am
Vacuum leak help discovering06 Tech & Performance Forum 11 14 Jan 2011 03:33 pm
vacuum line bhunt41 Tech & Performance Forum 0 02 Jan 2011 03:19 pm
Vacuum hoses PTcruzer02 Tech & Performance Forum 3 22 May 2010 07:23 pm
