HELP 06 PT Cruiser not starting
Like Tree2Likes
  • 1 Post By heifetz17
  • 1 Post By mdfrodolives
Old 27 Aug 2012, 09:54 am
Default HELP 06 PT Cruiser not starting
This may be difficult to explain. I'm in NJ and my son is in Kissimmee, FL. He has 06 PT Cruiser. Recently had water pump and timing belt replaced, about 1 month ago and just put in a new battery, about 1 wk ago. The other night he went to leave work and the car wouldn't start. All electrical systems work. When he turns the key there isn't even a clicking noise or anything and if lights are on, they don't dim. Trying to get some answers/ideas for him so he doesn't get ripped off. He doesn't currently have internet access, so I'm working on his behalf to find so possible answers. Thanks in advance for any and all suggestions.
Old 27 Aug 2012, 10:42 am
Talking Re: HELP 06 PT Cruiser not starting
Neutral start switch is a good place to look. Shake the gear lever. I would also check the connections on that new battery.
Old 27 Aug 2012, 10:48 am
Default Re: HELP 06 PT Cruiser not starting
Thanks for the quick reply. I know his next question will be where's the Neutral Start Switch?
Old 27 Aug 2012, 11:22 am
Inside the transmission on top of the valve body. That's not a good place to start unless he wants to take his transmission apart.
I would start by checking battery voltage and making sure the starter is getting voltage when turning the key.
mityqwik likes this.
-Chris
Old 27 Aug 2012, 06:57 pm
mdfrodolives's Avatar
I had a battery that was bad--but the lights still shone nice and bright. Still, there was not enough power to get so much as a "Click, click" out of the starter. Weird, right?
Anyway, I got a new battery and cleaned up the battery clamps really well, and checked under the battery terminal insulation a little to see if any corrosion had come along (and that part was okay). So I clamped the battery clamps on, sprayed some CRC Battery Protector on the posts and clamps to keep out that nasty corrosion, and ...
... I started her up and all was good.
Even if the new battery is "new" have it checked again, in case you got a dud.
Tim
Old 28 Aug 2012, 07:18 pm
Thanks for all the help and suggestions. Talked to my son today. He had the car towed to a local shop and they ran diagnostic. Said it was the ignition. Their price to repair is $628. Seems a bit high to me. He's in Orlando and this quoted price supposedly is discounted due to his being a Disney employee. I saw one online auto parts place had the ignition for $45-$50, is it really that difficult and involved to replace that would result in such a high price for a mechanic to replace a $45 part?
Old 28 Aug 2012, 07:56 pm
That's a lot like the buddy buddy price or the closer kin the deeper in price.
pt cruiser 2007 not starting FrankiezTundra2012 General PT Cruiser Discussions 2 14 Jul 2012 12:00 am
2005 PT Cruiser Not Starting TJHookor Tech & Performance Forum 10 28 Jan 2012 07:09 pm
2001 cruiser not starting KingJames Tech & Performance Forum 2 21 Jun 2011 10:10 am
Help with starting 2001 Pt Cruiser Doc60 General PT Cruiser Discussions 10 10 Jun 2010 07:27 am
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
