In between a whine & winding noise, almost a hot rod sound...running very rough
Old 27 Aug 2012, 07:18 pm
Angry In between a whine & winding noise, almost a hot rod sound...running very rough
Hello I have a 2007 Touring edition with 65,000 miles, automatic. Short history on vehicle, in April the crank shaft seal blew causing a crack in my engine block. Thank goodness the 8 yr 80000 powertrain through Chrysler covered that. I had a very bad shaking problem recently so both front top and bottom motor mounts were replaced, they were basically metal to metal and the motor was moving a less than desirable amount....close to 1/2 foot.
I heard a strange pop before motor mounts were replaced but even after, I still have the following problem although shaking has decreased tremendously. The gas pedal feels very shaky and I hear a very strange noise...as stated, in between a winding noise and a whining noise ( I know, bad explanation) almost but not quite a grinding noise. It almost sounds like a hot rod I guess, kind of. I did the 3 key turn code reading trick and no codes came up. I am at a total loss as to what could be wrong but I know it is not driving the same, as a owner/lover I have gotten use to how it drives and feels. Any help would be appreciated.
Old 27 Aug 2012, 07:29 pm
Default Re: In between a whine & winding noise, almost a hot rod sound...running very rough
Maybe all that movement help an axle go bad.
Running rough, sometimes... primostoy General PT Cruiser Discussions 10 16 Jul 2012 03:52 pm
PT GT running hot and rough AC idle thefish General Turbo Discussions 1 10 Jul 2012 07:19 am
Ideling and running rough? War_Eagle Tech & Performance Forum 5 04 Nov 2011 08:48 am
Rough running '06 GT CruzinGT General Turbo Discussions 14 21 Nov 2010 08:45 pm
01 PT Running Rough lucky594 Tech & Performance Forum 5 17 Aug 2007 11:22 am
