Replace crankkshaft Sensor
Like Tree2Likes
  • 2 Post By MiketheImpaler
Old 31 Aug 2012, 12:05 am
Default Replace crankkshaft Sensor
Hi,
I have a PT Cruiser that has its share of repair issues. I've used this forum to learn how to fix them myself. When I was researching where the crankshaft sensor was located, I either got incorrect info or a sketch that did me no good. I did learn from this forum that the location was under the starter. Anyway, I made this video of where the sensor is and how to replace it. I figured I'd share since there is not that much out there and definitely no videos of how to replace it.
Thanks,
Mike
2005 Basic PT Cruiser: No air and had to replace oil sending unit, crankshaft sensor, replace wheel bearings, new driver side front axle, replaced motor mounts, replaced valve cover gaskets. Waiting for the next adventure...
Old 31 Aug 2012, 10:49 am
2step's Avatar
Default Re: Replace crankkshaft Sensor
Points for good first post..........+1
Points for clever screen name....+5
Welcome, new guy.
Old 20 Sep 2012, 09:52 pm
oldorange's Avatar
Default Re: Replace Crankshaft Position Sensor (error code P0335)
THANKS FOR THE VIDEO!!! RE: Replace Crankshaft Position Sensor (error code P0335)
My 2003 PT had been, on occasion, while driving at 45-80 MPH range, for just a moment, hesitating?, cutting out?, doing a hiccup?...just for a flash... Then it started to happen more regularly, then on the generally uphill from the beach to anaheim hills area in orange county drive home doing that every few minutes, just for a split second, enough to be noticeable. Then today it threw the P0335 code. &
First it was a Check Engine Light flashing and alarm sound. After pulling over and shutting it off, then did the 3 turn key dance to read the code. After this I restarted and the Check Engine was now Solid, not flashing. I drove home cautiously. BUT THERE IS NO WAY I CAN REPLACE THIS SUCKER!!!
Hope my mechanic won't charge me a fortune.
My 2003 PTOS... ...Will it ever STOP Squeaking & Creaking???!!! And 21 MPG, what's up with that?
Old 20 Sep 2012, 11:52 pm
Be sure to use Original Chrysler sensor. Aftermarket sensors fail after about 500 miles or so. Had same problem,check engine light bucking at 2000 rpm etc. Original sensor works like charm..
Old 21 Sep 2012, 07:09 am
oldorange,
Your sensor is in a different place than the original poster. 2001-2003 has the Crankshaft sensor right above the oil filter. In 2004 Chrysler changed where it is to under the starter motor. Yours is MUCH easier to replace if you decide to change it yourself.
Like aameralis just said, ONLY use genuine MOPAR sensors for a replacement.
Old 25 Sep 2012, 11:16 am
oldorange's Avatar
Thank you gentlemen, the deed was done yesterday for $40 for the installation. I never looked near the oil filter for it, thought from all i could find it was under the starter. I guess I shoulda asked the mechanic where he found it, if as you say it is in an easier location on 2003's... Then again, I bought this PT with a engine that was replaced with a used one from a wrecked PT, and so maybe it could be a different year engine? not sure how to tell if this is the case, (and the seller was telling the truth about it, he didn't say the year, just gave me 6 months and 6000 miles warranty) or if it is the same year engine, or even the original motor, I have no idea.
I drove it about 30 miles and didn't notice any hiccups, and no codes so far again, hopefully it won't break down for my daughter who just borrowed it for a few weeks
Mechanic says it was under the starter motor. ?? !!
Also, I bought the part from pepboys, sorry.... hope I'm not sorry... (it has a lifetime warranty!) but i asked for a 2003 PT cruiser sensor... I guess I'd better find out what year motor this really is? MORE
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Crankcase sensor /Camshaft sensor PigFarmer Tech & Performance Forum 21 20 Mar 2012 07:01 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
replace alt ptsw PT Cruiser Convertible Forum 2 16 Oct 2011 05:14 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
