2007 pt cruiser rough idle with check engine light
Old 31 Aug 2012, 09:04 pm
Default 2007 pt cruiser rough idle with check engine light
I have a 2007 PT Cruiser that runs rough, the check engine light is on and when at idle it chimes and then blinks, when I proceed to move forward it chimes again and stays steady. The code is a #2 cylinder misfire. I have had the spark plugs, wires and ignition coil replaced. Can anyone help me? Any ideas as to what is going on?
Old 01 Sep 2012, 07:34 am
Default Re: 2007 pt cruiser rough idle with check engine light
When you had the plugs and wires replaced, you should have had a compression check done to rule out internal problems. You might try spraying some WD-40 around the No#2 upper intake running and around the area where the upper and lower intake come together looking for a vacuum leak.
2007 PT Cruiser Check engine light and transmission problems. jpierce2087 Tech & Performance Forum 18 22 Oct 2015 08:30 pm
2001 PT Cruiser check engine light reset kris115 Feedback and Support 4 19 Aug 2012 12:06 pm
'06 Cruiser Check Engine Light. plumbertom Tech & Performance Forum 6 04 Jan 2011 11:41 pm
2007 GT - Rough idle & Stall RainWind General PT Cruiser Discussions 4 27 Mar 2009 11:21 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
