Wiring diagram for side mirrors
  • 1 Post By Bluej
Old 31 Aug 2012, 09:31 pm
Bluej's Avatar
Question Wiring diagram for side mirrors
Does anyone have the wireing diagram for the 2001 cruiser power mirrors? They are not heated and I have looked for it in my manual and online and cannot seem to find it. I was given a set of after market side mirrors that are obviously not OEM matching harness and I just need to know which color wire operate up, down, in and out. And help would be appreciated. TIA
Old 31 Aug 2012, 11:47 pm
Default Re: Wiring diagram for side mirrors
If ya can't find a schematic do it the old fashioned way with a alligator clip and a good ground, find out when ya push the up which one gets hot, connect it to a wire on the mirror, ground the mirror and see if it moves the right way. if it does mark it down go on to the next button, when ya get them all use water-proof connectors (heat shrink or liquid) Grounds are usually white. OR use a sharp probe on a multimeter before cutting anything and find a solid body ground NOT in the door and do the same thing. If the mirror has five wires it doesn't need an external ground. Should be simple enough.Just don't short anything the controller won't like it
Old 01 Sep 2012, 12:52 am
Badglas's Avatar
Page 8W-62-5 of the FSM will show you all you need to know. If I could figure out how to attach a pdf file I'd post it for you.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 01 Sep 2012, 03:02 am
Bluej's Avatar
Thanks Badglas! Knowing exactly what to look for on line helps. I found it and will proceed with the operation as planned....
Badglas likes this.
2009 a/c wiring diagram cruzerdad Tech & Performance Forum 2 19 Aug 2012 07:58 am
Wiring Diagram clint21anne Tech & Performance Forum 10 24 Jun 2012 11:44 pm
PCM wiring diagram PTcruzer02 Tech & Performance Forum 0 10 Nov 2009 09:35 am
Need Radio Wiring Diagram 2006 Tintellaar Sound and Security Forum 4 02 Jul 2008 10:45 pm
Radio Wiring Diagram for Dummies TexasPriest Sound and Security Forum 2 25 Mar 2008 09:55 pm
