Hello everyone!
Old 01 Sep 2012, 09:26 am
Default Hello everyone!
I was on here reading a discussion but then decided to register so i can't find that post anymore. but anyways, it was a post about an o2 sensor. My 02 Pt Cruiser failed smog due to a PSP sensor (power steering, right?) and it's running to rich (so i bought an 02 sensor) i also read that there are two o2 sensors, mine is bank 1 to rich? Does anyone know which o2 sensor is affecting my car? And also how hard it is to replace both of these items? With the 02 sensor I went the easy route and bought the plug in one, since the other one required splicing wires. If anyone can help me with my issue i would greatly appreciate it!!
Old 01 Sep 2012, 09:45 am
Default Re: Hello everyone!
Both sensors plug into existing connections so neither should require cutting of any wires. On your fault code, you need the second number of the code. There's only one BANK so the fault code should read "bank 1 sensor 1 (or 2). The 1 would mean UPSTREAM sensor, 2 meaning DOWNSTREAM.
UPstream on top of the exhaust manifold.
DOWNstream by the CAT
Old 01 Sep 2012, 11:09 am
I looked at the smog paper, they said the codes are P0551 Sensor range/Performance. (this does mean the power steering switch right?)
And P0172 System too rich.
Do you know which one i would need to replace with that second code?
And thank you for your help so far. the diagram is great! I wanted to take it to a mechanic but I've had such bad experience with mechanics on this car
I think i can get my dad to do it i just want to be able to give him all the correct information before he touches anything ( He's a body man, not really a mechanic)
Old 01 Sep 2012, 11:37 am
Read this for your P0172 code. More involved that I thought.
error code p0172 ?
The P0551 is the power steering switch. Easy to replace but a messy job.
Old 02 Sep 2012, 10:41 am
Oh man!
Hmm, I'm wondering if it might be the fuel injectors...i was having an issue with my car sputtering really bad when I tried to start it for awhile, then all of a sudden it didn't want to start at all, so i literally had to floor the gas pedal for it to even start...and i had to leave my foot on the gas pedal for a good while....
and then the problem went away? Idk my car is a mess right now! I've had some problems with it :/
I blew a headgasket on my way back from Texas, cause my water pump went out...and somehow while it was at the mechanic my computer was fried....
and I've had an electrical issue...where it just wouldn't start at all, not even through a jump. We had to pop the clutch to get it going, and then one time i had the door open, with my foot out and it was windy...
and everytime the door would hit my foot, my gauges would go crazy (it actually made my speedometer fly all the way around and i had to unplug my battery to make it go back to normal...) weird huh?
anyways enough ranting....all in all i love my car, and im just worried about how to make it pass smog!
Thank you for all your help....
and the diagrams are great!
Old 02 Sep 2012, 11:18 am
Welcome from West Virginia! I would go and clean all the battery connections and follow the wires and clean those connections also. That requires taking the cables lose were ever they are bolted. The batter may be a bit tired and can cause some weird electrical issues. Then we can see what's left after that.
