hissing noise behind climate controls?
  • 1 Post By crazyptguy
Old 01 Sep 2012, 10:54 pm
crazyptguy's Avatar
Default hissing noise behind climate controls?
my 03 has devloped a very faint but noticable hiss from behind the climate controls i looked around for a hose or something that would hiss and found nothing has anyone else ever had this?
03 Pt Woody Classic 116k miles Rebuild project.
Old 02 Sep 2012, 12:00 am
Default Re: hissing noise behind climate controls?
The fresh air-recirculation control is operated by vacuum. You may have a vacuum leak in the tubes or connection behind the climate controls.
Old 02 Sep 2012, 12:01 am
Badglas's Avatar
I've not had this problem, but there are several things that can cause it. The most likely is a supply line to the heater controls, or the controls or actuators. The FSM has a description of the components, as well as how to test each system. You will need a vacuum pump to run the tests. The section you need begins on page 24-13 of the FSM. Good luck!
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 02 Sep 2012, 01:17 am
crazyptguy's Avatar
i thought the red and black lines were wires but thats where its comin from i must have caused it when i was changing bulbs. is it a vital thing or will i be ok taping it up
Old 02 Sep 2012, 01:32 am
Badglas's Avatar
That's hard to answer without seeing it. It is vital for two reasons. 1 It provides vacuum to allow the climate control to work properly, 2 It is a vacuum leak. How are the lines damaged? Are they pulled out of a connector or are the lines themselves broken?
Ron
Old 02 Sep 2012, 07:07 am
If it's a puncture from testing for power. You can dab a little weather strip adhesive or even super glue over the hole!
Old 03 Sep 2012, 01:57 am
crazyptguy's Avatar
the push on connector seems to be leaking like one its holes has been stretched out i cut off the connector and then pushed the lines on the nipples and the leak stopped
Badglas likes this.
popping and hissing moorepc Tech & Performance Forum 4 27 Jan 2012 08:50 pm
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Hissing noise jona_20017 Tech & Performance Forum 3 09 May 2011 01:46 pm
Climate Control Light ID meder2487 General PT Cruiser Discussions 4 21 Jan 2011 04:55 pm
Hissing Noise - Please Help? Slowpoke Tech & Performance Forum 2 10 Dec 2008 05:13 pm
