Throttle problems - loose enginepart
  • 1 Post By sanatanadharma
Old 02 Sep 2012, 01:48 pm
Default Throttle problems - loose electronic component on the engine
Hi!
Lately I have been struggeling with engine stalls (after stopping at red lights etc). I get the P2107 Throttle Control Module code. In the beginning it just happend once in a while, but this weekend it started to happen almost every time I stop the car for a red light and start driving again.
I had a look tonight and found a strange component that just was hanging in its harness under the throttle body. The hole throttle body "stand" is loose, and one of the bolts holding it to the engine is gone. And I guess the component should be fasten to the same bolt holding the stand.
Does anybody know what this is? Its connected to the harness with the cable to the coil.
Could this be the problem of the P2107? I havent been able to fix it yet. To dark outside where the car is parked.
Old 02 Sep 2012, 01:59 pm
Badglas's Avatar
Default Re: Throttle problems - loose enginepart
I'm not sure what Chrysler calls it, or if it has anything to do with your code, but I can tell you where it mounts. In the attached picture follow the upper heater hose and you will see it is mounted on the throttle body support bracket.
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 02 Sep 2012, 02:00 pm
i have no clue what that is but i see a green wire and the bolt that holds it on is under the coolant line the arrow points at.
Old 02 Sep 2012, 02:04 pm
The bolt holding it and the support bracket is gone, so I think the component didnt have any connection to ground. I am crossing my fingers that this is the cause of my throttle problems. I havent been able to figure out what the component it self is... But it seems to have something to do with the ignition system
Old 02 Sep 2012, 03:07 pm
Default Re: Throttle problems - loose electronic component on the engine
Ignition coil capacitor? My guess.
Originally Posted by DrLaban View Post
Hi!
...Does anybody know what this is? Its connected to the harness with the cable to the coil.
OurPTGT likes this.
Old 03 Sep 2012, 03:10 pm
Both bolts on the support stand was gone!
After installing new bolts and the loose capastitor - the check engine light dissapeard before I was able to do the fault search with my dongle and smartphone.
Took it for a spin and had no problems. A little early to say that it fixed it 100%, but its very promising =)
Yesterday I also found out that the throttle house was VERY dirty, so tomorrow I will receive a bottle of "KENT One Shot" that I ordered today.
Old 04 Sep 2012, 09:24 am
SpannerHound's Avatar
Smile Re: Throttle problems - loose enginepart
It's a suppressor, it's meant to absorb any back emf from the ignition system so that electrical noise is limited at the PCM
Old 04 Sep 2012, 11:55 am
That would explain ALL the wierdness that has been with this cars electronic system!
Something Loose in Rear End markroach Wheels, Tires, Suspension 1 22 Jul 2012 11:22 pm
Loose Bolt ALIfromtheCIA Tech & Performance Forum 3 31 Jan 2011 08:42 pm
loose center cap LNBNDN Wheels, Tires, Suspension 1 21 Sep 2010 01:51 am
Loose Throttle Cable? ucantcme General PT Cruiser Discussions 1 18 Sep 2008 07:03 pm
LOOSE LUGS?? soonercruiser Wheels, Tires, Suspension 5 17 Jan 2008 11:01 pm
