Check Engine comes on
Old 02 Sep 2012, 03:07 pm
Default Check Engine comes on
2006 PT Cruiser GT Engine lite comes on and car will not turn over sometimes . When it does start it only has second gear and reverse . Turn car off..let sit for a few seconds...start back up everything ok most of the time. Put car on computer diagnostic and they cannot determine what the problem is but they want to replace the computer engine modular.
Old 02 Sep 2012, 04:19 pm
Default Re: Check Engine comes on
put your key in the ignition.
Then turn it from off to accessory and back to off 3x.
Where your odometer is it should give you a PXXXX code. Let us know what the code is and we may be able to help ya out :-)
Old 02 Sep 2012, 05:00 pm
If the above instructions aren't clear, follow these:
How to retrieve fault codes.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 13 30 Apr 2012 04:49 pm
Check Engine vikz Tech & Performance Forum 9 04 Aug 2011 02:25 am
Check Engine=Most Annoying mjb457 Tech & Performance Forum 1 02 Jan 2011 09:32 pm
CHECK ENGINE BORICUA General PT Cruiser Discussions 9 10 Aug 2004 07:58 am
