2001 pt turns over..wont start
Old 02 Sep 2012, 06:38 pm
Send a message via Skype™ to twharned
Default 2001 pt turns over..wont start
here is a doozy, my 2001 pt died on me at a light getting off the freeway....scan tool gave me misfire codes and I had no power to my fuel injectors....so I looked around as the head was recently done. Found the fuel injector harness not quite clipped all the way. So I clipped it back and together...figured I was done.....then it spit out 340 cam error code...replaced cam and crank sensors, checked wiring I have 8.9 volts to the sensor, ground appears good as well.....still code 340.....put a used pcm in it cranked it a few times, still got error code 340 even though my key did not communicate with the brain.....what now?
Old 02 Sep 2012, 07:25 pm
Default Re: 2001 pt turns over..wont start
take the cam sensor out and see if the cam turns when you crank it. most likely timing belt if ur ~100k.
Old 02 Sep 2012, 07:50 pm
XXXXX2 on that!
Old 03 Sep 2012, 10:13 am
I hate to say it but....BINGO..its the timing belt, I was gonna pull a compression test next, but no need now...funny thing is I would expect it to turn over alot faster...but it dosen't...thx guys, I guess I know what I will be doing today...lol
Old 03 Sep 2012, 04:37 pm
Well didn't hurt anything at least. Will be ready for another 100k when your done.
Old 11 Sep 2012, 04:01 pm
well..the tensioner broke, belt looks so-so, went with the mopar factory retro kit, but looks like the new tensioner style bolts from the motor mount plate?
wish i had some pics to help....anyone know where to find them?
Old 11 Sep 2012, 04:30 pm
Don't know if this will help. Not a close up.
Old 15 Dec 2013, 01:10 pm
I have a 2001 pt cruiser touring edition. I have only had it since March 2013 and in the summer when it was in idle at a red light or just in general it would start to over heat. Well the the one day in the summer it over heat and there was an orange fluid leaking out. Well i let my car cool down for about an hour and it was able to drive again. Well in July I was driving home from work and my check oil light came on and my car just died. everything worked the lights and radio but when it died i could turn properly or press the break in enough. I go to start it and it turns over but wont turn on. i changed the one sensor and i have tried jump starting it and leaving it on a battery charger over night and it still will not turn on. any ideas?!
Old 15 Dec 2013, 02:42 pm
randyincctx's Avatar
Lightbulb Re: 2001 pt turns over..wont start
Originally Posted by vmsnyder93 View Post
any ideas?!
Yeah,you might want to start your own new thread,as this one is over a year old,and also because it sounds like you may have 1,2,or 3 different issues going on at once with your PT Cruiser.
Aka:~KILLER~
Old 16 Dec 2013, 03:37 am
Crewzin; the cam sprocket timing marks are off.
Nice overall picture. And so clean!!
02 PT WONT START sgtwsky Tech & Performance Forum 2 15 Jan 2014 05:39 pm
02 wont start Sfos Tech & Performance Forum 15 10 Jan 2014 05:46 pm
Car Wont start!! txgalant8 Tech & Performance Forum 6 06 Nov 2012 07:45 am
Engine turns over and but dosen't start first thing in morning Jimmydog100 Tech & Performance Forum 10 14 Dec 2009 05:06 pm
2001 Wont start. Freshly charged battery thakfu General PT Cruiser Discussions 4 19 Jan 2009 02:14 pm
