Is it possible?
Old 02 Sep 2012, 07:00 pm
Default Is it possible?
So i've been thinking of my rough idle issues that i cannot figure out for the life of me.
And i remembered something. Right before this started i remember removing the upper intake manifold to access my plugs/wires to see if the plugs were burnt.
Later on when i removed it again to change the plugs, i noticed a small amount of oil around the gaskets in the upper intake manifold.
Could bad gaskets here be causing a compression loss and causing my car to hate idling? and should there be oil around these gaskets?
Old 02 Sep 2012, 07:20 pm
Default Re: Is it possible?
i'm leary of the brass inserts walking out of the plastic. i think i squeezed one back in with a pliers iirc. i think my gaskets were greasy too. i just wiped them off.
spray it with soapy water and see if it bubbles. it's a holiday weekend (:
Old 02 Sep 2012, 07:34 pm
Spray some starting fluid on the seems very lightly to see if the idle picks up. if there is a leak it will suck it in and you will hear it. If you over tighten the inserts will pull up. Should put some super glue and quickly push it back into the hole. Just a little, you don't want to get any in the threads.
Old 02 Sep 2012, 07:37 pm
mdfrodolives's Avatar
I've opened my upper manifold several times. Each time, there was oil on the gaskets (from the PVC valve letting it in). You might just change the PCV valve if a lot of oil was in the upper manifold. Also, check the PCV valve hose for wear and tight seal. Mine was cracked, so I replaced it.
The rough idle suggests a vacuum leak that may be caused by something you didn't put back together properly. And you might go ahead and replace the upper manifold gaskets to make sure the vacuum leak is not because of them.
The upper manifold bolts should be tightened to 105 inch (that INCH--not pounds). Did you use a torque wrench? Did you tighten the center bolt first. Then the one right of center. Then the one left of center. Then the one to the far right. Then, last, the one to the far left.
Tim
Old 02 Sep 2012, 09:31 pm
Tim
i always crisscross when tightening bolts :-) just the way to do it.
How do you find inches in tightening. my torque wrench only shows Lbs.
Im just trying to figure it out. I know i have a teeny tiny head gasket leak. But nothing big enough to lose compression on, i dont even lose oil or coolant from it.
My fuel pressure is good, only code im showing is a intake temp sensor but.that went well after this problem occurred.
Checked the tension on my timing belt and condition, that all checks out.
I've hosed all the vaccume lines with carb cleaner and no change in idle..
But she just wants to bog down and die when it idles for more than a minute or two....
Im almost at the point of dropping a new engine haha
