Upper EGR tube gasket
Like Tree2Likes
  • 1 Post By Badglas
  • 1 Post By Rippsnorter
Old 04 Sep 2012, 03:14 pm
Default Upper EGR tube gasket
I'm having a hard time finding the gasket for the upper end of the EGR tube where it connects to the intake manifold. Anyone know where to find one?
Old 04 Sep 2012, 03:26 pm
Default Re: Upper EGR tube gasket
The Chrysler part number for the gasket is # 05277928. You might have to order it from the dealer.
I take that back. You can order it here for $3.10
http://www.factorychryslerparts.com/...roduct=4325856
Old 04 Sep 2012, 03:57 pm
Badglas's Avatar
I got mine from the dealer. It was in stock for about $6.
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 04 Sep 2012, 04:04 pm
That's different than what's on there. It's a round rubber gasket
Old 04 Sep 2012, 04:56 pm
Can't find that as a separate number. Looks like it comes with the tube itself. Maybe someone else can find it.
Old 04 Sep 2012, 05:56 pm
Badglas's Avatar
I know it is available as a separate part, I just bought one. I'll look for the receipt. I'll post the part # if I find it. I do know it is called EGR tube seal. I could not find it in the aftermarket.
Ron
Old 04 Sep 2012, 08:03 pm
Badglas's Avatar
Okay, receipt found. Part # is 4591250 Seal EGR 14072009. I purchased this last month, so the number should be accurate.
Ron
Rippsnorter likes this.
Old 04 Sep 2012, 08:59 pm
awesome thanks alot!
Badglas likes this.
Where is AC drain tube TedT-CA Tech & Performance Forum 2 20 Mar 2009 01:40 am
EGR Tube gasket, o-rings, grommet, washer breadtrk Tech & Performance Forum 4 31 Dec 2008 08:39 pm
Air tube mods oldcoach Tech & Performance Forum 0 27 Oct 2007 06:48 am
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
