Question about my engine.
Like Tree4Likes
Old 04 Sep 2012, 08:12 pm
PTCruiserNoob's Avatar
Default Question about my engine.
Lately my cruiser has been jerking at times when it's idle. At the same that this happens all the lights on the dashboard and needles/gauges go crazy. Feels like it's stalling out.
any help would be greatly appreciated.
Old 04 Sep 2012, 08:20 pm
Default first thing to check...............
Check your battery leads. Check all your ground cable or straps points. Maybe even while you are looking around plan where you will be installing a few more needed grounds.
More possible solutions for you soon to be posted by our friendly forum members.
Welcome to the forum. You might want to go to the welcome area and say hello?
Welcome New PT Cruiser Members - PT Cruiser Forum
^^^^^here^^^^^
OurPTGT and Busted_PT like this.
Old 04 Sep 2012, 10:44 pm
Default Re: Question about my engine.
a friend of mine mentioned it being a camshaft sensor, but i have no idea.
Old 04 Sep 2012, 11:24 pm
I agree with Nitro.
Camshaft sensor would cause rough idle, no starts and heating. But would do nothing to the gauges.
Check the battery posts, terminals, leads, grounds and have the battery and alternator tested. its a power issue.
Old 05 Sep 2012, 09:29 am
Originally Posted by pluminator View Post
I agree with Nitro.
it's not overheating, just rough idle and jerking at times. Maybe i should replace the sensor anyway?
gonna check the posts, terminals and all those other things first though.
Old 05 Sep 2012, 09:45 am
Kawizx9r's Avatar
If you replace any sensors, you should specifically use Mopar parts. PT's don't like after-market anything when it comes to sensors/electronics.
Kawi is a friggin genius!
Old 05 Sep 2012, 11:20 am
Your friend is wrong. Do no replace things that don't need to be replaced. This is not a sensor problem, it's a power problem, as Nitro pointed out. Check your battery and connections, and check your alternator.
pluminator likes this.
-Chris
Old 05 Sep 2012, 05:12 pm
2step's Avatar
I also doubt the sensor but check for trouble codes to be sure. And while you're in a checking mode, check the plugs and plug wires. The dash lights and gauges acting up makes me think it's a low or failing battery. Place my bet there.
Old 05 Sep 2012, 06:34 pm
mdfrodolives's Avatar
Perhaps it's the tires. After you've put in that new sensor, get some ....
Tim
JamUp likes this.
Old 24 May 2013, 07:27 am
Default NO FUSE/no radio/mirrors/no locks/speedo random
Please help. (No Fuse) Checked iod fuse and cleaned ok power through box 12.5 volts ok cleaned all earth leads ok, New battery, leads all sanded for good contact ok All fuses in car ok/ Still not working. HELP Terry U.K.
engine swap question Wonderjava Tech & Performance Forum 11 16 Jun 2012 06:33 pm
Engine Question. Alex_Clarke General PT Cruiser Discussions 32 17 Jan 2011 05:02 pm
Engine question hurlermom101 General Turbo Discussions 2 04 Aug 2010 11:38 am
Gt engine question careyk General PT Cruiser Discussions 1 21 May 2008 01:36 am
Engine Question! b0b88 Tech & Performance Forum 7 03 Apr 2008 05:27 am
