Dead Cruiser-Bad with cars
Old 05 Sep 2012, 12:09 pm
Unhappy Dead Cruiser-Bad with cars
Hi,
I have a 2004 cruiser with about 103,000 miles on it. It has been doing the shaking/bucking thing when I am stopped in traffic or at a red light for a long time now. It died not too long ago and the mechanic replaced the battery (for $180!) and said I could wait a while on a tune up (don't remember ever having one). I had the oil changed earlier this year also. Yesterday I was waiting to pull out in traffic and the car had died and I didn't even realize it. When I tried to restart the check engine light and oil pressure light came on and it sounded like it wants to start, but won't. My fiancee came to the rescue and pushed my car to our apartment and upon inspection it was low on oil and coolant. We added both and let it sit overnight and nothing today. The electrical is working (I think), I can get the ac to come on and it makes a turning noise when I try to start, but doesn't catch. It has died like this before, when it would shake real bad, but it always started right back up. This time it wasn't shaking/no noise at all and it won't start. Any help would be great, he is going to try to look at it when he comes home. Thanks-
Old 05 Sep 2012, 12:25 pm
Default Re: Dead Cruiser-Bad with cars
HOLY COW! Not sure where you live but, a battery for my cruiser cost $59.95 with free installation at Wal-mart, Autozone or advance was not much more. Sorry but i would have told that mechanic to shove it.
What do you mean by earlier this year? Do you have it changed every 3-4mths, or 3500-4500 miles? Maybe a little bit longer with sythetics..
Does it start shaking really bad when the A/C is on, and quit when the a/c is turned off? If so its most likely the cooling fan. Any time a car dies, the oil light and check engine light is supposed to come on, they usually go off when the car is restarted.
A few more things, have you done the "key dance" to check for computer codes? And with your car at 103K miles, have you checked the timing belt, these notoriously fail at or around 90k-100k miles.
The above paragraph is a starting point, we need to know any codes before anyone can semi-accurately diagnose the problem at hand.
Old 05 Sep 2012, 12:26 pm
Originally Posted by jordyw1 View Post
Hi,
Possible causes.
Clogged Catalytic converter
Broken timing belt.
Camshaft sensor
Crankshaft sensor
Plugs/wires
Coil pack
Starter
Alternator
Fuel Injectors
Fuel pump
Fuel filter
EVAP system
Head gasket *causes compression loss*
is it showing any codes?
Put the key in the ignition and turn it from "off" to accessory, then off again 3 times in a row.
where your odometer should then flash P0-xxxx 1-10 times with different codes. Write them down and let us know what its telling you :-)
We can go from there.
Old 05 Sep 2012, 12:35 pm
Hi and thanks for the responses! I just pulled the codes and got:
P0522
P0340
I think for the first one it is referring to engine oil pressure sensor and for the second camshaft position sensor circuit (from what I read on other posts).
It is definitely due for an oil change and tune all around. It does quit shaking when the ac is off.
I will try to look at the timing belt, but have no tools and don't think it would be smart for me to take anything apart myself, because I have no idea what I'm doing.
And again, thank you for the help!
J
Old 05 Sep 2012, 12:44 pm
P0522
P0340
J
Take it to a shop and have them swap the oil pressure sensor, and the CSPC and CSPS
Run ya bout $225 with labor but.......have them check the fan, timing belt and water pump :-)
Old 05 Sep 2012, 12:49 pm
Thank you- and I just have to get it started or towed first. I live in New Orleans and was out of work for a week due to the storm, so hopefully we can get it in soon and it won't cost too much. I am going to try to peep at the belt in the meantime. Thanks again!
Old 05 Sep 2012, 03:03 pm
cruserdad1976's Avatar
i think i read all the post but did you say you have never had the timing belt changed???? if not then the best guess is it snapped well more likely it chewed off some teeth this is a expensive reapir and if you paid almost $200 for a battery id be scared to see this bill
At a good dealership it will be around $1200
at a better local shop id say between $7-$900
parts are under $200 Timing belt water pump tensioners---it comes as a kit
the labor is what will kill you
actually a oil change change the oil sensor and the Timing Belt would be a nice thing btu its gonna hurt for awhile
Old 05 Sep 2012, 03:05 pm
one more thing it will not in any way start if the timing belt is bad no matter what you do it just wont start and there is no sence to do anything else till that is fixed
and the last thing you cant really see if the belt is bad it may look good but the teeth will be chewed off
Old 05 Sep 2012, 06:42 pm
mdfrodolives's Avatar
For now, it sounds like a bad fan, a bad Cam Sensor, and after the car starts and runs--as soon as you can afford it--a new timing belt (it was due at 90,000 miles).
Also, when your car starts running like an old VW Bug that someone poured a bad of sand into, you might start getting things looked after as soon as the symptoms occur. When stuff happens, it just gets worse when you keep putting off the issues.
And get a new mechanic.
Good luck,
Tim
Tags
won't start
Need Advice on Dead Cruiser doctorwholittle Tech & Performance Forum 2 27 Dec 2011 12:06 am
So, I have a dead PT Cruiser in my driveway... tpm Tech & Performance Forum 2 26 Mar 2011 12:20 pm
My Cruiser is officially dead AlTheKiller General PT Cruiser Discussions 5 26 Oct 2009 06:46 pm
Pic, Cruiser back from the dead turbomangt The Detail Shop 3 23 Dec 2004 10:45 am
Vote PT Cruiser one of "Greatest American Cars" Sci-Fi General PT Cruiser Discussions 2 04 Jul 2002 12:54 am
