P0340 Error code on 2003 PT Cruiser
Old 06 Sep 2012, 05:25 pm
Default P0340 Error code on 2003 PT Cruiser
Hello,
I have a 2003 PT Cruiser, Auto, 75000 miles.
I am getting a P0340 error code on my PT cruiser.
The check engine light was on for three days, but them when off for ~ 2 weeks.
It came back on yesterday, but when back off today.
The cars runs good most of the time. Sometime the car have problems with it idle when the AC is running when I am at a stop light. ~ 10% of the time.
Any ideals on what the problem can be?
Should I replace the CAM sensor?
Thank You
Bert
Old 06 Sep 2012, 06:02 pm
Default Re: P0340 Error code on 2003 PT Cruiser
Bert,
That is the code for the Camshaft sensor and either it could be going bad or maybe the wiring harness may have a short. If you do your own maintenance, take a good look at the harness for any wear and tear especially around the back of the engine.
Your ruff engine running with the A/C at a stop light might be because the radiator fan is running properly. In the morning when everything is cool, start the car, turn on the A/C and see if the fan is running. It should be. Every time the A/C is engaged, the fan should be ON. If not, one speed of the fan could be burned out. Common problem with the PT.
P0340 error code and wont start. jdwalk04 Tech & Performance Forum 5 28 Apr 2012 12:05 pm
P0340 error code and wont start. jdwalk04 Tech & Performance Forum 0 27 Apr 2012 11:23 am
Error Code p0340 fallynangel Tech & Performance Forum 7 10 Dec 2011 09:03 pm
2005 PT Cruiser GT is getting a P0340 error. silverwolf22 General PT Cruiser Discussions 1 20 Jun 2010 05:03 pm
Error code P0340 ADVICE??? mjb457 Tech & Performance Forum 10 20 Aug 2009 09:24 pm
