90,000 mile maintenance???
Old 07 Sep 2012, 03:54 am
Default 90,000 mile maintenance???
I have a 2003 PT Cruiser, std. 2.4L engine and automatic transmission, that just turned 90,000 miles and plan to have the timing belt replaced and a tune up next week. Is there anything I should have looked at while it is in the shop?
I remember when I had a tune up years ago someone here suggested a certain plug brand, and wire brand. I guess the mechanic can tell the brand of plugs and wires when he gets under the hood but I remember that the gap suggested was just a little different than Chrysler recommended.
Thanks for the advice, Bill
Old 07 Sep 2012, 08:11 am
Default Re: 90,000 mile maintenance???
Any decent brand of plugs and wires will work. Chrysler did come out around 2004 and suggested the non-turbo cars should be gapped at .040 in. instead of the .050 in. that was originally posted.
Along with the timing belt, the water pump and belt tensioner should be changed as the both wear out and it takes the same amount of time to change (5 to 7 hours) as the timing belt itself so might as well get them done.
Also won't hurt to change the serpentine and alternator belt while everything else is being looked over.
What's up with PT maintenance davidg Tech & Performance Forum 4 03 Aug 2011 03:56 pm
60k maintenance screnwriter General PT Cruiser Discussions 10 03 Jul 2011 06:46 pm
30,000 mile maintenance parkertam General PT Cruiser Discussions 5 15 Feb 2007 02:46 pm
30,000 to Maintenance To Do ? okonrad Turbo Performance 8 16 Mar 2005 02:10 am
