Engine/vehicle "shudder" in 2nd gear?
  • 1 Post By geohunt
Old 07 Sep 2012, 05:12 pm
Default Engine/vehicle "shudder" in 2nd gear?
Have a 2005, auto trans, 2.4L w 39,000 miles.
When accelerating from a dead stop, vehicle/motor pulls/accelerates nicely in first gear, when 2nd gear kicks in, vehicle/motor seems to struggle/shutter somewhat (you can almost feel it in the driver's seat), then third gear kicks in and everything is smooth again.
Have replaced wires, plugs, air cleaner, PVC valve, cleaned throttle body, and thrown a bottle of fuel injector cleaner in the gas tank. No check engine light or codes.
Also had lower control arm verticle bushings and right lower engine torque strut replaced as well as a new camshaft position sensor installed. Installed new radiator fan motor/assembly as well.
Have any idea what it could be? Are these PTC's just a bit under powered and I'm just feeling the 2.4L motor struggle a bit?
Thank you so much,
George in Pa.
Old 16 Sep 2012, 04:51 pm
Default Re: Engine/vehicle "shudder" in 2nd gear?
Problem was bad driver's side, drive axle shaft not engine mounts or torque struts if that helps anybody.
Busted_PT likes this.
How to install the center motor mounts, or "Right engine mount" Leroy PT Cruiser Videos 0 21 Aug 2011 08:21 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
MSD Coil Type For "B" engine PTZee Tech & Performance Forum 2 06 Jun 2009 01:27 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
