04 ran good for a week, now acting up again.
Old 09 Sep 2012, 08:42 am
Default 04 ran good for a week, now acting up again.
Well my daughter's 04 Cruiser ran good for a week after changing the fuel pump. Last night it stalled again, but was able to limp home. Codes showing now are
:P0201 Injector 1 Control Circuit
P0202 Injector 2 Control Circuit
P0203 Injector 3 Control Circuit
P0204 Injector 4 Control Circuit
Plus: P0032 and P0038, the O2 sensor codes I always get when it's running bad. Even though I replaced bothe sensors. The air bag light even was on.
This is what's been changed, both O2 sensors, fuel pump, cam sensor, crank sensor, plugs and wires.
Antone have any suggestions?
Bob
Old 09 Sep 2012, 10:07 am
Default Re: 04 ran good for a week, now acting up again.
pump is new and running close to 60PSI as it should, injectors cant handle the load and are probably spraying at 46-49PSI. need to be swapped out for 24lb injectors :-)
then the PCM needs to be reset. Unplug the battery for 10 minutes and that should do it.
Old 09 Sep 2012, 01:28 pm
Pluminator,
Are the 24 pound injectors stock one's?
Bob
Old 09 Sep 2012, 01:59 pm
for a 2.4 yes 24lb is as close to stock as you can get.
22lb injectors run around 42-46PSI which is underpowered and would give you some studdering issues :-)
Old 09 Sep 2012, 02:51 pm
I just don't buy in on that all 4 injectors crapped out at once. I would think that something common to all 4 injectors such as the harness or some thing that controls the injectors would be more likely. JMHO
Old 09 Sep 2012, 04:55 pm
agreed. a compression test while the car is running will tell you whether its the injectors or a wiring issue :-)
Old 09 Sep 2012, 07:06 pm
What makes me think it could be a wire harness is that the air bag light is on. The car runs fine until the check engine light comes on. I don't think I have a wiring diagram, could the injectors and air bag light be hooked into the same harness. Does anyone know which plug on the fire wall contains the injector and air bag wires?
Bob
Old 09 Sep 2012, 07:49 pm
Bob
Sense you said something about the light being on, I'm thinking you may have a flaky cam sensor. Sometimes they don't throw a code.
Old 09 Sep 2012, 08:00 pm
I first replaced the cam sensor about a year ago, threw a code for it. After the car started stalling I put another one on since it had a life time warantee. Onece when it stalled I checked if it was putting a signal out and it was. I looked at it tonight, started it and CEL and airbag lights were on. Looked at the wiring for the injectors and unplugged all the connectors at the ECU on the firewall. Restarted it and neither light came back on. Drove it for a couple of miles and it ran good.
Bob
Old 09 Sep 2012, 08:14 pm
Bob
Like unplugging and plunging a computer board. Lets hope that's all it is.
My Pt Gt has been acting weird. NicksCruiser Tech & Performance Forum 19 09 Jun 2012 11:28 am
PT is acting weird when A/C is on the_jeep_now Tech & Performance Forum 13 22 Aug 2011 09:42 am
So my Trans MIGHT be acting up? Cathy06PT Tech & Performance Forum 6 11 Nov 2008 10:57 am
Dash acting weird Nikkortim General PT Cruiser Discussions 8 04 Sep 2005 06:30 pm
My PT is acting up at 68K miles (VERY BAD) Ctown General PT Cruiser Discussions 2 11 Mar 2005 11:10 am
