opinions on double platinum plugs?
Like Tree3Likes
Old 09 Sep 2012, 12:26 pm
Default opinions on double platinum plugs?
2005 base 2.4L 22,000 mi 1'st spark plug change for this vehicle!
planning to use double platinum
any opinions as to whether they're good choice for car used mainly for local commuting, low annual miliage?
objective is maximise reliability, gas mileage, time to next plugs change.
Old 09 Sep 2012, 12:54 pm
Default Re: opinions on double platinum plugs?
i've got champion double plats in both my cars (2001 and 2002). no problems.
Old 09 Sep 2012, 02:32 pm
Same here. Champion Double Platinum Number is #7570
Old 09 Sep 2012, 05:16 pm
I tried em in my Neon DOHC.....burnt up quick. but that was a weak 2.0. Personally i use OEM however i've heard good things about them in the 2.4 PT's :-)
Old 11 Sep 2012, 09:34 am
Be sure and change the plug wires - and DO NOT use stock wires.
I've had 2 PTS and on both the stock wires started giving me misses before 20,000 miles - put in Crane wires and no problems since.
I believe and good name brand wires will be fine.
Gap at 0.050.
Old 11 Sep 2012, 11:45 am
Originally Posted by quicksilverdon View Post
Gap at 0.050.
TSB 08-008-04 noted a new Champion spark plug specification and a new gap - 0.040 inches replacing the prior 0.050 inches.
Old 11 Sep 2012, 12:31 pm
My bad - I knew that. 0.050 was the original gap - corrected to 0.040..
Old 11 Sep 2012, 01:48 pm
2step's Avatar
"opinions on double platinum plugs?"
Maybe it's just me, but I think you should only use one plug per cylinder.
wwpptc, Vlefaive and Chip18sw like this.
Old 11 Sep 2012, 01:55 pm
Texas humor.
Champion Double Platinum Plugs.
Champions longest life plug, designed to replace original equipment platinum plugs. The fine wire center electrode and tapered side electrode aid in focusing the spark for better performance while both the side and center electrodes are also platinum tipped for superior erosion resistance (longer life). A triple sealed interior and copper core reduce failure to heat and stress.
Old 18 Sep 2012, 05:55 pm
I just bought a 2010 Classic to replace my base 2007.
So, the current wisdom is 7570 Champions @.040? I remember another Champion plug number in 2009 when I replaced them in my 2007.
I used Bosch wires in 2009 for my 2007 but see nothing listed for 2010's. Is that simply a listing error?
If I go back from 2010 I get D9477 or D9858 for Bosch wires. Thoughts on which ones will work best.
Thnx!
Autolite Double or Single Platinum Plugs? falconut Tech & Performance Forum 2 08 Jun 2010 03:19 pm
Double platinum plugs? Rt66Bob Tech & Performance Forum 2 14 Mar 2009 09:11 am
platinum plugs airevac19 Tech & Performance Forum 5 21 Apr 2004 11:30 am
another question re platinum plugs pingber Tech & Performance Forum 7 31 Aug 2003 12:55 am
Platinum Plugs Not Tex Tech & Performance Forum 10 28 Jun 2002 07:12 pm
