torque spec for intake manifold
Like Tree3Likes
Old 09 Sep 2012, 12:59 pm
Default torque spec for intake manifold
I've seen plugs spec'd @ 13 lb-ft,
what is spec for intake manifold bolts when changing plugs?
Old 09 Sep 2012, 01:30 pm
Default Re: torque spec for intake manifold
i didnt bother to do this with mine, but since you asked..
4drturbo likes this.
Old 09 Sep 2012, 01:45 pm
wow, can't beat that for a response thank you very much!
Old 09 Sep 2012, 03:26 pm
That is for the plastic intake. If you have an aluminum one, it's different torque specs.
Old 16 Feb 2014, 02:07 pm
Torque same on the PT Cruiser GT plastic IM?
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Old 16 Feb 2014, 03:43 pm
The illustration and information is for a plastic intake manifold.
Old 16 Feb 2014, 05:35 pm
So you are saying the IM is the same on both the GT and base NA?
Old 16 Feb 2014, 05:38 pm
Far as torque specs. They have the same hardware. The brass nut in the plastic. It is possible the lower is the same on both.
Old 16 Feb 2014, 06:18 pm
Nice. Well I used those torque specs and all is good. I see there is only 1 company that makes the replacement rubber o-rings too.
Old 16 Feb 2014, 07:11 pm
I did not say that the NA and Turbo intakes were completely the same. but as Danny said the torquing vales and sequence are the same.
Personally I am very cautious with the recommend torque values if re-using the soft seals.
You may look again for how many supply the soft seal there are actually a few.
Bolt torque spec for when replacing timing belt? unioncreek Tech & Performance Forum 4 20 Jul 2012 04:31 pm
Torque setting for Manifold? jhn_plsn Tech & Performance Forum 15 08 Mar 2011 02:35 am
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
Intake Manifold turbo_pt2003 General Turbo Discussions 11 18 Dec 2009 01:51 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
