smelly a/c and heater
  • 1 Post By Badglas
Old 09 Sep 2012, 01:37 pm
Cool smelly a/c and heater
Am just cleaning up an 04 PT that I just purchased. Looks great and was out for a test drive and turned the A/C on.......ouch, smells like dog....wet dog hair.....when the air was put on.
I searched the forum for info on a cabin filter.....confused here, some threads talk about a filter system for air and some threads talk about the PTs' not having a cabin filter. I just want to get the dog smell out. Will try to clean the airways with detergent and fabreeze. Anyone know about a cabin filter and where I should look to change it out? THX
Old 09 Sep 2012, 02:06 pm
Badglas's Avatar
Default Re: smelly a/c and heater
Welcome to the forum. Stop by the new members forum and introduce yourself. A search turned up several threads, this one looked like it might help.
Ron
Cabin air filter
Busted_PT likes this.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 09 Sep 2012, 10:27 pm
thx badglas just as I had thought. Will check out the John Deere filter tomorrow and install just like the instructions in your link. THanks again
Old 09 Sep 2012, 10:41 pm
Badglas's Avatar
Glad I could help. You might also make sure the evaporator drain is clear. After running the A/C while driving, you should see a small puddle of water under the right front, towards the dash. If not, you'll need to clean the drain. If the drain is or has been plugged, it could be causing your odor.
Ford had a problem with this in the late nineties, I think. There are disinfectant kits available if it turns out to be a mold or mildew problem.
The other consideration is a deceased rodent. Unusual if the car didn't sit for an extended period, but not unheard of. I have pictures of several mouse nests found in the dashes of Corvettes built in 90 days. They move in small, get comfortable, gain weight, then die when they are too fat to get out.
Had one C5 that I found 5lbs of Pinto beans in the heater blower assembly.
Just some further thoughts...
Ron
Heater smell discovering06 Tech & Performance Forum 5 23 Dec 2016 12:31 pm
Heater Aodoggie General PT Cruiser Discussions 7 27 Jan 2012 06:06 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
Smelly Air Conditioner! auntwendy9 Tech & Performance Forum 3 24 May 2008 08:02 am
Smelly air-conditioner 1lowufo General PT Cruiser Discussions 3 19 Jul 2004 09:42 am
