02 cruiser lunges and jerks
  • 1 Post By OurPTGT
Old 09 Sep 2012, 03:18 pm
Default 02 cruiser lunges and jerks
2002 touring w/ 5-sp, 70,000 miles. Car lunges and jerks while accelerating, usually in 2nd gear - Sometimes just once, sometime as many as 4 times in succession (as if driven by someone just learning to drive a stick). I'm not getting a check engine light and the "key dance" produces no codes. Any help would be greatly appreciated. Thanks...
Old 09 Sep 2012, 03:37 pm
Default Re: 02 cruiser lunges and jerks
As the doctor would say, "Son, I need more information if you want a decent diagnostic."
When was the last time you did anything like plugs and wires? What gap are you using? Have you checked fuel pressure at the Schreoder valve? Sounds like a fuel problem. Tried injection cleaner?
Old 09 Sep 2012, 05:14 pm
agreed. Tried cleaning out the fuel rail with some carb cleaner?
Sometimes stuff that gets past the fuel filter will build up in the fuel rail, thus when its put under load it just sucks small particles into the injectors and causes a sputterish thing. :-)
If you clean the fuel rail, wait 15 min or so before putting it all back together so that you dont suck carb cleaner fumes in, cause then shell stall and it can mess with the wiring harnesses :-)
Also if you do this make sure to replace the O rings on the injectors, soak em in gas before installing them or you wont get a good seal :-)
Old 10 Sep 2012, 09:30 pm
my car did this before i filled the engine mounts. this is actually the reason i did it.
if you get down and look in the passenger wheelwell in front of the tire, is the rubber in the mount torn up?
Old 11 Sep 2012, 07:29 am
maybe soak them in gas to clean them but you should coat them in clean engine oil when installing them. Kinda like the oil filter seal
wwpptc likes this.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Car Jerks Terribly When Letting Off Gas Pedal paulrosenthal Wheels, Tires, Suspension 1 11 Jun 2011 05:09 am
Car jerks before stopping jessica2001 General PT Cruiser Discussions 1 30 Oct 2010 05:48 am
2001 PT Cruiser hesitates and jerks into reverse/drive BranVonWolfe Tech & Performance Forum 19 28 Sep 2009 05:05 pm
My cruiser shakes/jerks at idle and near 50mph cruizen01 Tech & Performance Forum 2 09 Apr 2009 08:56 am
Jerks and Sputters on Start Ikster Tech & Performance Forum 6 20 Sep 2008 09:05 pm
