Drivers Door signal
Old 09 Sep 2012, 08:07 pm
Default Drivers Door signal
Hi All, my PT is a 2005 2.2 manual diesel right hand drive that I drive in the UK.
I am trying to fit GPS/SMS/GPRS tracker system on the car, on ebay for about 50.
The wiring diagram that comes with the tracker says that its drivers door trigger wire shoud be connected to the car so that it can send a text message to tell me that the car has been broken in to as well as the present GPS location of the car.
In the wiring diagrams that I have downloaded on line for the car, they show a TAN/BLUE wire as the (-) nagtive door trigger.
I have located the wire at the drivers side door next to the sub fuse box on a multi connector.
When I tested the voltage to earth (car has negative ground) using a digital multi meter I did not see anything other than a sort circuit all the time, even when I open and close the door manualy. Am I supposed to see a flash of negative? In which case it would be worth connecting the wire from the tracker to the the door, or am I missing something? regards Pat.
Drivers door arm rest white Interior Accessories Forum 2 21 Nov 2011 07:50 pm
I need a drivers door DuanefromPA The Detail Shop 8 21 Jun 2010 12:38 pm
Key does not work in drivers side door adriennemetalsmith Sound and Security Forum 4 02 Jun 2010 07:07 pm
Drivers door not latching roborob76 Sound and Security Forum 7 19 Nov 2009 09:03 am
Key won't open drivers door! littleblueGT General Turbo Discussions 3 20 Aug 2007 10:32 am
