What is this part?
Like Tree2Likes
Old 09 Sep 2012, 08:43 pm
Default What is this part?
What is this part circled in red, and why is it sweating? I cleaned it before taking a picture, but it was covered in black sutt that smelled like gasoline.
Old 09 Sep 2012, 09:09 pm
UptownSport's Avatar
Default Re: What is this part?
It's a little accumulator or something that's part of the fuel line.
They always leak
You'll need to buy new fuel line
Old 07 Nov 2012, 06:52 am
have same problem which fuel line needed. From firewall to fuel rail or from fire wall down ( haven,t looked to see where it ends up there. been lurking a few days but wife smell gas in her 2006 non turbo and you have exactly same problem
Old 08 Nov 2012, 04:08 am
You are correct
Old 08 Nov 2012, 04:42 am
It dampens pulses in the fuel system. It is replaced as an assembly with the fuel line to the rail. If it is leaking, replace it immediately...don't allow any leaking fuel in the engine compartment...fire hazard.
Old 08 Nov 2012, 12:36 pm
since that is all it does, could you not just replace it with a small piece of fuel injection hose? i mean, rather that purchasing a new fuel line, i would try bypassing it first. it would never fail again. spending $5 on hose and clamps vs buying a new fuel line with a part that is prone to start leaking gas seems like a no brainer to me.
IDK it may not be the best idea, but that's what i would do.
i like how they mount it practically right over the hot exhaust manifold. that's cute.
Old 08 Nov 2012, 02:30 pm
the '94-97' or so didn't have the thing, '98-'99 did, but on fuel rail.
'00 and up have it in same place as PT; used a '00 & up Neon line on my leaking PT ...
but please don't you do that.
Old 08 Nov 2012, 06:32 pm
Badglas's Avatar
If it wasn't needed, it wouldn't be there. The fuel line is just over $50 new at the dealer.
You could bypass it as rob suggests, but you run the risk of ruining the line that runs the length of the vehicle to the firewall. Plastic lines were not meant to be used with hose clamps.
I replaced the line on mine. Given the location, I wasn't willing to risk losing the vehicle to fire over a $50 part.
Ron
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 08 Nov 2012, 08:04 pm
I'm surprised you even noticed that part 'sweating', back low on the firewall like it is. Glad you did not go looking for it with a lit match...
Old 09 Nov 2012, 02:51 am
PART ID GovMule Tech & Performance Forum 6 19 Apr 2011 02:24 pm
I NEED THIS PART! Please help! TheCity88 General PT Cruiser Discussions 7 14 Sep 2010 11:47 pm
ALL IN ONE Part....Help??! ucantcme General PT Cruiser Discussions 8 22 Aug 2008 04:03 pm
Name this part coolvirus General Turbo Discussions 18 26 Apr 2004 11:25 pm
pt part # tom Tech & Performance Forum 0 02 Oct 2002 09:07 pm
