Oil in my #1 Cylinder
Old 11 Sep 2012, 10:25 am
Default Oil in my #1 Cylinder
Yesterday I was giving my 2006 PT Cruiser a much needed tune up. I changed out spark plugs and wires 2-4 with no problems. But when I got to #1 I pulled the wire and oil was dripping off of the end of the wire itself. So I didn't cause any more damage I didn't even try to pull and replace the last spark plug. What do I need to do to fix this problem in my car?
None of my spark plugs are misfiring and I haven't noticed any oil dripping from underneath my car as well. I have been having some problems, though, when I am stopped at a red light for a long period of time my RPM's drop below 1 and my AC starts blowing out hot air, but once I start driving again I don't have any problems.
Thanks in advance for all advice and help given.
P.S. my engine is a 2.4 L engine as well.
Old 11 Sep 2012, 10:39 am
cruserdad1976's Avatar
Default Re: Oil in my #1 Cylinder
First the oil in the plug hole is common with motors like thee
its not a big deal a couple things can cause this if by #1 you mean the first on nearest the oil filler cap you could ahve gotten some oil in there when you fill the car
or tjhe seals could be leaking and allowing some oil inot the hole
Id pull the plug and look at it and see if it is oily or a nice white color if its white put in a new plug and rock on
the getting warm air I wouls say your fan has died in the low speed and if you are not really carefull or lucky you will get your car hot
with the AC on the fan should be on low even if the car is cold in fact even if the car is in 20 degree weather if you turn on the ac the low spped fan should be running
Old 11 Sep 2012, 11:51 am
with both of the answers given by Cruserdad.
Old 11 Sep 2012, 01:02 pm
Also if when you pull the plug, If there is oil on the interior of the plug, your valve cover gasket/plug grommets are gone. cheap and easy fix though.
Old 11 Sep 2012, 02:28 pm
Thanks Crewzin i actually tryed to get most of the words readable
Old 11 Sep 2012, 02:41 pm
Well.....lets just say that if it wasn't you, I might have said something about the punctuation but I know your on that tiny little screen that'll make you go cross-eyed in later years.
Old 11 Sep 2012, 03:22 pm
Hey Crewzin
had a buddy hit a deer sat night 2 sherrifs deputies showed up they l driving the new charger with the 5.7 hemi they seem to really like them except they are kind of small on inside room so they are going to the new Police Interceptor Taho and as we were waiting on a wrecker one of the new ones showed up man that is a sweet ride in Phelps county they let the boys take there car home with them which I thought was kind of cool btu them i guess it just lets everyone know that a Office lives here so who knows St james has gotten a grant for 5 new tahos should be a lot of chargers on the merket
Cylinder 3 misfire michalo187 Tech & Performance Forum 12 28 Jan 2017 09:30 pm
Wheel cylinder PtOnAir Tech & Performance Forum 5 29 Aug 2011 05:03 pm
2.4 Cylinder Head '03-'10 UptownSport Classifieds: For Sale/Trade 1 29 Mar 2011 09:04 pm
Misfire In Cylinder 4 shoe989 Tech & Performance Forum 13 23 Feb 2011 03:56 pm
Cylinder Misfire TaylorMade Tech & Performance Forum 6 16 Jun 2005 05:01 pm
