Turns over but won't start
Like Tree2Likes
Old 11 Sep 2012, 11:41 am
Default Turns over but won't start
I have an 06 non turbo pt crusier. After replacing a bad battery it turns over but won't start. I replaced the spark plugs and verified that I am getting a spark. I checked all the fuses in the box behind the battery, they appear to be fine. I swapped the ASD relay with the one next to it ( there the same) located on the back wall of the engine compartment, drivers side just under the windshield. My next move is to replace the crankshaft position sensor. Before I do is there something I've overlooked I should check? please help.
Old 11 Sep 2012, 11:48 am
Default Re: Turns over but won't start
How many miles on your PT ???
Old 11 Sep 2012, 12:24 pm
Thanks for responding, 77,000.
Old 11 Sep 2012, 12:28 pm
Sorry It's at 72,000
Old 11 Sep 2012, 12:53 pm
Remove cam sensor and see if they turn while someone cranks it.
Old 11 Sep 2012, 12:59 pm
What Busted is saying is that it's kind of early but there's a chance that the timing belt has broke. We see it a lot on the forum.
The camshaft sensor is located on the side of the engine (see picture). It's easy to take off. Once it's off, have someone crank the engine as if trying to start the car while you watch the end of the cam where you took off the sensor. If the timing has broken, there won't be any movement at the cam end because the belt moves the cams.
Old 11 Sep 2012, 01:25 pm
Thanks for the pic. and info, I was hoping for another suggestion like pushing some hidden reset button. I'll have to wait till later when I have someone to turn the key. I'll let you know what I find out, meanwhile if the timing belt is ok, would the crankshaft position sensor be my move to fix this?
Old 11 Sep 2012, 01:51 pm
The Crankshaft or Camshaft sensor would stop you from starting the car but BOTH should throw a code if anything is wrong. Do you have the engine light showing which means you have a fault code?
Old 11 Sep 2012, 02:50 pm
Prior to the battery going out, no check engine light was on. I turned the key 3 times and got dashes for a couple seconds then it said done, engine light was on during this time. The cam is turning (Wheew). What do you suggest I check next?
Old 11 Sep 2012, 03:23 pm
Spark and fuel are your two main reasons why it won't fire and you verified the spark. I know how to check the fuel pressure on the 01-05 PT's but don't know where they might have moved the test valve on yours, if there is one.
2001 pt turns over..wont start twharned Tech & Performance Forum 11 22 Jan 2015 02:39 pm
radiator fan turns on and off superjew78 General PT Cruiser Discussions 4 22 Jul 2012 10:28 pm
turns over, but no fire carolinagirl Tech & Performance Forum 6 04 Aug 2011 07:54 pm
My PT is OVERHEATING when the A/C turns on...not the fan!! kletson General PT Cruiser Discussions 8 10 Jul 2010 08:25 pm
Engine turns over and but dosen't start first thing in morning Jimmydog100 Tech & Performance Forum 10 14 Dec 2009 05:06 pm
