Overheating
Old 14 Sep 2012, 02:18 pm
Default Overheating
My car has been overheating and we cant figure out why. We have changed the thermostat, the raiator, water pump, fan motor, flushed the system, thermo sensor, and the bleeder. I can hear the water boiling and it overheats. There is no water it the oil. Please help. I dont know what else to do.
Old 14 Sep 2012, 03:23 pm
Talking Re: Overheating
Have you been to a dealer?
Old 14 Sep 2012, 03:42 pm
Default Re: Overheating
NightWing,
People come here to try and fix their car before paying the exorbitant prices that the dealer wants to diagnose a problem and then some of them throw parts at the problem just hoping to fix it.
PTmom,
Is their any kind of leak anywhere showing that your loosing coolant? Is the system being bled for excess air after you fill it up? Are you using the A/C when it overheats and did you try turning on the heat inside the car to stop the gauge from going into the red? You changed the radiator fan but did you check to see if it's running when it starts to get hot?
What year is the car and what mileage do you have? You said you changed the water pump? That's a 5 to 7 hour job and quite expensive. Did you have the timing belt changed at the same time?
Old 14 Sep 2012, 03:55 pm
"People come here to try and fix their car before paying the exorbitant prices that the dealer wants to diagnose a problem and then some of them throw parts at the problem just hoping to fix it."
Yes, I understand people come here to learn what they could possibly do themselves. In this case, it appears that the owner has invested a fair amount of money in the car and the problem still exists. A dealer visit may have found the problem and cost less in the long run.
Old 14 Sep 2012, 03:57 pm
Old 14 Sep 2012, 04:02 pm
One post is enough to state your opinion.
Yes, the dealer might have saved him some money, but since he already put out quite a bunch, the forum members could possibly set him in the right direction without putting out too much more. With the dealer, he's starting off at around $100.00 just to look at it.
Old 14 Sep 2012, 04:40 pm
I know. The double post was a mistake and I couldn't delete it. Anything else?
Old 14 Sep 2012, 05:04 pm
Originally Posted by NightWing View Post
Anything else?
Not until we hear from PTmom.
Old 14 Sep 2012, 05:19 pm
Default double post
when I double post I go edit it with a smiley or a differnt comment.
They didn't mention replacing the radiator cap!
This stock PT one on the left no longer seals which can add to an over heating problem.
Old 15 Sep 2012, 04:11 pm
Check for plugged cat converter
Overheating snowwhitetiger General PT Cruiser Discussions 7 31 Mar 2012 09:48 pm
Still Overheating? JSRocket Tech & Performance Forum 9 13 Aug 2011 01:33 pm
PT OVERHEATING!!!PLEASE HELP mtlhead79 Tech & Performance Forum 11 28 May 2009 09:21 pm
Overheating PT! mikedb Tech & Performance Forum 9 09 May 2009 04:45 pm
overheating missejd1963 General PT Cruiser Discussions 3 03 May 2009 08:39 pm
