2004 Will not crank or start
Old 14 Sep 2012, 03:49 pm
Default 2004 Will not crank or start
Hi,
My daughter's 2004 PT will not start or even crank. It quit running on her. Then it started and she drove a short distance and it quit again. We had to have it towed home. It has just over 100,000 miles on it.
Now it will not do anything when we turn the key except turn on lights. The battery seemed okay. I tried jump starting it with the same results.
I tried to do the "key dance" as described in this forum but I did not get any codes or anything on the odometer.
Has anybody had this problem before? I think it is maybe the security module but I don't know how to check it.
Any suggestions other than take it to a dealer? I will take it Monday to a local repair shop if I cannot figure anything out before then.
Thanks,
Glenn
Old 14 Sep 2012, 03:53 pm
Ray_Dockrey's Avatar
Default Re: 2004 Will not crank or start
How old is the battery? I have had them where they were so bad that they wouldn't jump start. It might be worth replacing if it is very old.
Also, have you had the timing belt and water pump changed? Normally a broken timing belt won't cause it to not crank but weird things happen.
Old 14 Sep 2012, 10:18 pm
The battery is a maybe three years old. I tried jump starting it and I also tried starting it using a different battery. No difference.
The timing belt and water pump were changed about a year and a half ago.
Thanks,
Glenn
Old 15 Sep 2012, 07:03 am
Check all the wiring from the battery (both negative and positive) and make sure there's good contact both at the grounding point and the starter solenoid. Look for any corrosion built up at the ends of the cables.
Old 15 Sep 2012, 08:19 pm
The battery wires are good. I cleaned them early in this process. The main ground looks good. I have not yet checked the starter connection yet.
Glenn
Old 16 Sep 2012, 11:39 am
jrbsr05pt's Avatar
You said you tried the "keydance" and nothing showed up. You should still get the word done to show up even if there isn't any engine codes. Try it again and see if there are any codes or if it says done.
Originally Posted by gatorglenn View Post
Hi,
Thanks,
Glenn
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 18 Sep 2012, 05:58 pm
I tried the Key Dance several times and got nothing. I took it to a local shop. They found a burnt out fuse under the hood. Will get more details tomorrow. They did not find any reason for the fuse to burn out, so it could happen again.
Glenn
Old 19 Sep 2012, 04:00 pm
So it's running now?
My hunch would've been ignition switch.
Old 19 Sep 2012, 05:35 pm
It is running the same as before. Not great but running. It was the most expensive fuse that I have ever bought but they did spend an hour looking it over to see why the fuse blew and they changed the oil.
I stopped and bought extra fuses today, just in case.
Glenn
Old 04 Oct 2012, 03:51 pm
Let me guess fuse number 13 fp/asd Under hood That popped I am having the same problem But my car will stay on for 5 seconds. From my reading there's a short in the wiringwould or fuel pump is drawing too much current do you drive low on fuel all the time? Would like to know the end results if you got it fixed.
2004 won't start scurvynave General PT Cruiser Discussions 5 03 Jul 2012 05:34 pm
2004 PT will not start. unioncreek General PT Cruiser Discussions 9 13 Jun 2012 09:32 am
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
01 stalled, no crank, no start - thoughts? darwal61 Tech & Performance Forum 7 06 Jan 2012 06:14 pm
2004 pt no start jeffersonjw Tech & Performance Forum 1 07 Oct 2010 01:42 pm
