Manual transaxle fluid fill
Old 16 Sep 2012, 03:52 pm
Default Manual transaxle fluid fill
I've seen on my Owners Manual Scheduled Maintenance booklet that the manual transmission fluid should be checked periodically. I can't find where on the engine this needs to be performed.
2003 Nissan Altima (Son's)
2011 Smart For2
2005 Chrysler PT Cruiser Convertible (Toad)
2006 Saturn Vue (Daughter's)
1999 Holiday Rambler Motorhome (Retirement home someday!)
Old 16 Sep 2012, 04:21 pm
UptownSport's Avatar
Default Re: Manual transaxle fluid fill
It's on the driver's side, above and to rear of driver's axle:
This would be looking at it from inside, obviously, see differential bearing cup, above is an oval recess with check hole in center
Old 16 Sep 2012, 08:39 pm
rcktpwrd's Avatar
Like Uptown said it's on the drivers side. There is a rubber plug in the side of the trans. Probably easiest to remove the wheel to get at it. The trans takes about 2.8 quarts of fluid. If it's an '01 it takes special fluid thats only available at the dealer, other wise it takes atf+4 just like the auto. FYI the special lube is expensive...
Joel
www.rcktpwrd.com
Old 17 Sep 2012, 08:45 am
If they're saying the '01 take a diff fluid than later years ...
Transmissions are exactly same '94-10, except slight changes
Transaxle problems? cocacola144 Tech & Performance Forum 2 02 Jul 2012 08:43 am
manual tire pump to fill the car tires? meganzhang Wheels, Tires, Suspension 5 30 Mar 2012 08:33 pm
2002 5-speed fill transmission fluid mbindy Tech & Performance Forum 5 10 Dec 2011 09:20 pm
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
Manual Transaxle Fluid dalkeeper Tech & Performance Forum 3 01 Feb 2010 06:51 pm
