Help With engine codes
Old 18 Sep 2012, 06:36 pm
Question Help With engine codes
Hello This is my 1st Post I have seen alot of posts on this website and you guys seem to know quite a bit.
Let me break it down for you.
Bought this car with messed up timing belt ( no bent valves thank god)
its a 2003 Pt cruiser base automatic.
Now when we put everything back iginition and most of the electronices were messed up. So I got a meachanic to fix it for me. He said everything worked except the speed sensor and that was because supposedly there electrical surge and messed up the computer. So I got a new computer and got it programed. I went home being told that the instrument cluster is bad. I went online Bought a used one from a reputable dealer for my model and type of car. I put it in and my speed sensor was still not working.
So even though he said he checked the VSS in and out and said they worked I went ahead and replaced those. just in case that was the issue.
Still have error codes. All the parts I have i know go to my car so its not that. I ran a code scan by doing the on off trick for the pt cruiser.
These are the codes I got.
P 0501
p 0137
p 0138
p 0633
I ran a instrument cluster test by holding down the trip button on startup and all the sensors moved like they were supposed to.
I have no Idea at this point why it is still acting up.
It shifts just fine. I do have issues with it Going extremely low on the Rpms when I stop. But only when I am in Drive. It will go to about 0.3-0.5 RPM up and down over and over again while I am stopped.However It does not stall out.
And of coarse my speedometer does not work. If you could please help me out I would greatly appreciate it.
Thanks in advance
Old 18 Sep 2012, 06:51 pm
Default Re: Help With engine codes
The middle two codes are for the oxygen sensor by the CAT.
P0501 Vehicle Speed Sensor Range/Performance. You still have a problem with the VSS.
I could only find the P0633 on the SRT forums and it means your SKIM is disabled. SKIM = Sentry Key Immobilizer Module.
Old 18 Sep 2012, 11:44 pm
So is it the input and output VSS because I replaced those with brand new ones. So could that be a wiring issue?
Old 22 Sep 2012, 12:29 pm
You can also go to the tech docs library in my sig panel below and pull down the Cruiser DTC's (diagnostic trouble codes) listing.
Old 22 Sep 2012, 08:13 pm
What should I be trying to do next though. If i have replaced the Both the VSS and the computer and the instrument cluster. What could be wrong that could cause the VSS code I posted above ?
Tags
engine codes, help please, pt cruiser 2003, troubleshooting
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
engine codes fy9-03pt General Turbo Discussions 5 18 Feb 2012 12:49 pm
engine codes petiecruiser Tech & Performance Forum 1 25 Oct 2009 03:48 pm
engine codes petiecruiser General PT Cruiser Discussions 3 25 Oct 2009 02:37 pm
OBD engine codes shodobe Tech & Performance Forum 7 27 May 2005 12:32 am
